Standard height coils lift my lc76 about 2 inch! Please Help!
Saudi Arabia
Hi everyone
I have absolutely no experience about car modification or suspension so please excuse my ignorance
I have LC 76, 2025 with 1GR FE V6 engine
Car relatively new only had about 15K in odometer
I replaced my factory rims and tyres from 16 inch 265 to 17 inch wheel and 285/70/17
And also added some drawers and water tank and some loads around 200-230Kg so car sags a little and I decide to do some lift
At Dobinson dealer here I only found 1 type of lead springs and coils whic is:
- L59-021-r leaf
-C59-454V “ Variable Rate Standard Height “ coils
- IMS Shocks
If I understand correctly, per website the coils not to supposed to make lift but dealer says they will lift somewhere between 2-3cm however after installing it lift about 4.1cm even thought I have factory winch but no modifications
Lead spring rated at 5cm but he says this is with empty loads and it should lift less than that around 4 cm but real results after installing that it lift exactly 6cm Which is higher than anticipated or rated or what I wanted!! Btw “ water tank and gas tank is 75% full.
  • Is this normals and these ratings for leafs and coils before buying not accurate ?
  • do they need some time to settle and become lower?
I appreciate the suggestions if there’s a modification to lower the car from front and back around 2cm.
Thanks you!
I see this all the time with with the Dobinson springs
I run there 2” springs and get 3” of lift.
I wonder if they ever explained it to you ?
I emailed them asking for explanation even about the leafs and no response! I’m so frustrated.
There made in Australia like just about every aftermarket Toyota Springs.
Watch some YouTube videos of Off Road in the outback. They carry everything well beyond the kitchen sink.
This is my opinion based on reading thousands of threads and unless your vehicle is heavily laden your going to get more lift then advertised.
I bought my springs used from another Mud member because the springs were giving him more lift than he wanted and was advertised.
I bought the "stock" height coil springs from Dobinson, and I am glad I did. They were pushing / highly recommending the 2" lift with their matched bushings. Their Stock Height Springs on my vehicle was easily 2" above what I had with the worn out Toyota springs. I would stay with Stock Height on the springs, IMO, unless you are doing serious off-roading and going big on tires.
^^* This
That’s unfortunate..
They do make a good quality products but such a huge difference in rate is something I just cannot accept .. I was looking for just a little lift
I can get around with the rear with removing one leaf but the front? Heard that some people cut the coil to reduce height but I won’t do that and I’ll keep looking for alternative that doesn’t lift more than 2cm.
Thanks
The only reason I changed the coils is because these new tires and rims was rubbing the front bumper sometimes and the car sags a little so I thought a little 2cm lift won’t hurt..
Then go with stock height. I'm an Americano. I was talking Inches, not Centimeters. You will be happy with stock height Dobinsons! Your aftermarket tires will NOT rub on anything 33" inches and below assuming you still have your stock Toyota Rims. Good Luck!
there’s no other options from Dobinson at the dealer and this one clearly stated as standard height yet lift over 4cm!
I gotta look for another company or cut the coils..
I contacted someone and he says he have a good option from me from Lovells that will only lift 2cm
Im searching about it .. Part number TFS-127
He did go with stock height. The difference between 4cm and 2 is minimal. 2 cm is .8 inches.
OP, why is this a problem? Are you having steering or driveline issues?
I do agree that springs advertised as stock height should be closer to actual stock height.
Hello,
I am late to the party.
Stock springs, whether OEM or aftermarket, have 25 - 30 mm or 1 in. or lift. As they settle, this lift decreases.
Springs that lift a truck 50 mm or 2 in. settle as well, though not as much.
If you drive with light loads (less than 400 kg or 900 lb or four people,) suspension settling will take a while. You can drive loaded to speed up the process.
Regarding removing leaf springs from a pack, it is possible. It may or may not change height or ride quality.
Install the Stock springs, drive your truck with a load of at least 400 kg, wait for the suspension to settle and do not overthink it.
Last but not least, make sure your springs are the light or medium option. Unless you carry heavy loads or spend a lot of time off road, the heavy option can be too stiff a ride.
Juan
No steering issue so far but it’s just car looks too high for my need. What i came to believe is that these ratings were for V8 diesel engines in Australian market .. whic is lighter than my engine and that cause the lift, Dobinson just confirmed that with an email!
Hello,
Juan
Thanks for sharing you opinion. Juan
I don’t understand what’s the point of going back and install the stock springs with 400Kg? I replaced them because they already sagged with 200kg load
What i have now is medium option from 021 model Dobinsons and they told me I can remove leaf No3 to become like their lighter option 020.
Hello,
OEM springs settle with 200 kg and the ride becomes softer. Aftermarket springs with stock height are a bit stiffer. They may or may not settle as much as OEM for the same ride.
If I remember correctly, medium springs are designed with a front load of 400 kg (bull bar and winch) in mind. Rear springs are matched accordingly, again, for a back load. All of this with a 2 in. lift. Heavy springs can bear a little more load. In order to handle this, they are stiff.
Medium (and heavy) springs are intended for off road use with a full load, front and back. On road with less than a full load, it is a harsh ride. And this is where the suggestion about removing leaves comes in.
I would ditch the medium set up and install a light one. Then I would drive with a load of 150 kg or so for a few weeks to settle it, and I would not look back after that.
Juan
i swear that any lift springs from aus do this as they have strict rules about lift height so they lie about how much the lift kit raises it, 50mm is more like 3"-4" in aus measuring
