Stainless Exhaust Installed
LC_Hamma
The Anti-Leafer
Dallas, Georgia
Finally finished the new exhaust - all stainless too!. I bought a Borla 2 1/4" muffler from Summit, had a custom collector flange made up, got some misc. prebent tube & hangers from JC Whitney, & welded it up. Oh yeah, I had to polish it up for all the mall cruisin I do. I cycled the rear suspension & the links do not hit the tubes:
you did'nt purge that did you? i can see the welds are all sunk in and if you look in the end they'll be all sugared up..... not that it matters on exhaust pipe.
Purging stainless..... Hmmm, didn't do my homework as I'm a newb at stainless welding. I told the welding shop what I was doing & they didn't mention it. I guess I'll take it apart & have the process done locally. Cost was around $300.00. A spool of stainless wire was around $350.00 & a small tank of argon was around $25.00.
That is definitely a nice setup. Good work man...
you're also going to have to flip it more often to show off that setup
Nice! This thread is useless without sound! :cool:
Brian, can you'splain "purge" for those of us who are amature welders and might try stainless sometime?
And I hope the wire was $35 and not $350!!!!:)
Ed
That's very cool, I'd really like to do something like that on my own 40. What kind of vehicle was the original Borla stainless exhaust system intended for or what's the part number?
Toyo FJ40 said:
From what I understand you need to purge tubing when you weld (not just stainless) which means you fill the tube with the welding gas so the weld doesn't oxidize on the inside during the welding.
Kevin
it's pretty much an SS thing, anything else short of alum would be an open butt joint.
Nope, you read it right, the wire spool was $350.00
but the real question is, when am I going to see this truck at Tellico?
This truck is a Tellico veteran, been to countless GSMTR'S & STLCA fall get togethers - where you been? So, the real question is when is your truck gonna be seen tackling Lower & Upper 2?
It's not a vehicle specific muffler. I just ordered a 2 1/4" offset inlet / centered outlet.
Well, since I've already welded the tubes, there's nothing I can do to prevent the inside from oxidizing (?)
Actually, I was there two days ago, and 2 months ago, I will be there again in 3 days, and again at the end of january. This was my 5th trip this year. I never could make GSMTR because my highschool exams were the same week.
Why don't you come up MLK weekend, we always have about 20 land cruiser guys campin and wheelin that weekend. I am definatly running upper 2 and schoolbus that trip.
I know that truck is a Tellico veteran, just hasn't been there since I've been old enough to drive :flipoff2:
While up there last week I ran slickrock during a hail/rainstorm at night, before the rain there was snow and ice on much of the face. Last time I ran right up the face with 33's no problem. This time, even with the addition of siped 38's I nearly rolled and had to pull cable.
Upper 2 has been in the plans the last 2 trips. Last time I snapped a driveshaft on slickrock. This time we couldn't make it to the trails in time one day to run it.
Don't worry, as soon as the truck sees either 2, you're gonna see pictures. :flipoff2:
This pic was taken right as I was tipping, that friend holding onto the running board is 6'4", if that gives you an idea of how high that side of the truck was.
This bit of info was cut & pasted from the masterfabber at Gordofab Engineering:
The "good ole" air you are breathing has contaminants that affect the weld integrity. These contaminants come into contact with the molten puddle during the weld process. The goal is to remove all air from the tubes being welded and replace it with the same gas you are welding with. This shields the weld from the contaminants. To do this you need an additional source of welding gas with its own regulator. A splitter on the gas bottle you have will work to give two gas sources. The hose on the second gas supply needs to be attached to one end of the tubing you are welding. Professionals typically have appropriate fittings that clamp onto the tubing but you can get by with a duct tape or masking tape. Just tape the gas hose into one end of the tubing enough to hold it in place and use addition tape to seal up the end of the tube around the gas hose. The other open end of the tubes being welded also has to be sealed but needs a small hole for gas to escape. Some people cut a piece of cardboard (not corrigated) to match the outside diameter of the tube. Put a small hole in the center of the cardboard. Hole should be about 1/16 to 1/8". Before taping the cardboard on the tube, turn on the gas and purge the tube. You should now be setup with one end sealed with the gas hose, the other end sealed except for a small hole, and a joint to weld somewhere between the two. Set the pressure regulator for the purging gas to about 5 psi or less. The purging gas now floods the tubing to prevent contamination. The open joint being welded and the hole in the cardboard cap allow gas to escape preventing pressure buildup. As the weld is completed the hole in the cardboard continues to releave pressure to prevent blowout of the final puddle of weld. If the final puddle does blow out the purge gas pressure is too high or the relief hole too small.
i use steel wool to plug the end of whatever im welding flow a good amount of gas inside then quickly stuff the wool in it should also do the trick..........
