SST for tightening on FF rear hub
Ben,
If you ar refering to the threaded holes in the rotor they are 8x1.25mm.
D-
Hmmm. Is there not two extra holes (that are threaded) in 80 series rear axle shaft flanges? there are the 6 tapered holes for the threaded studs and 4 smaller holes, two of which are for the smaller studs and two of which are threaded to assist in removal...? Like in the pic. Two of the smaller four holes in mine are threaded.
On a side not, on my 60 I don't have discs but drums, is the same 8x1.25mm thread used in my drums you think?
-Ferg-
Edit: Whoops, forgot the pic...
Ben,
The 2 "smooth" holes index with dowel pins in the hub. The threaded ones are used to assist in removall of the shaft. ;)
D-
Simon, I have total faith. If you build it, I will follow.
I haven't researched this rear axle task nearly enough, I'm having a little trouble following. ???
Riley
Mine works fine. I would have bought the real Toy one but I spent two days calling the dealer then bringing in the FSM with no luck. Went to NAPA for S's & G's and ordered one up. This was pre list and Cdan :)
Lag,
Better to know me now than never ;)
Ben, yup. :D
