SPUTTERING/HESITATING checked search
Los Angeles, CA
Website
www.phipsi.net
Keeping this as organized and simple to follow as can be:
Upon turning on the truck, no problems
1 min in, idle starts to fade in and out and sputter think "put, put, put,put"
When I step on the gas..it will have a very rough start and acceleration from 800-2000rpm then it sounds fine.
So far I have:
checked the oil - fine
check radiator - fluid is clear neonish no bubbles
coolant res. is rather empty
cleaned out the "tuna" can
cleaned out the air filter and box
replaced battery
check all hoses and plugs in the engine bay
I've noticed that the exhaust does put out some moisture while the truck is on. My exhaust is cut at the point right behind the upper rear control arm so after the truck has been on for a few minutes that moisture will collect on the mount and drop down onto the floor (always had some moistrue from what I recall)
Have not checked the spark plugs, plug cables, or the distributor yet.
I did clean and degrease the engine a week or so ago, but the truck was driving after that with no troubles).
I don't think it is the HeadGasket...,
BUT I'm throwing this out there to see if anyone else has had this problem and what potential solutions might be before I get to it on Sunday.
Thanks in advance and a BIG thank you to Alvaro for helping me out thus far.
Sam
So far I have:
replaced battery
Sam
Could be anything; check everything.:idea:
Are you saying it only stumbles for a few minutes after warming up, then runs fine, or it runs rough all the time.
What do you mean "the exhaust is cut"? No cats, no 02 sensors??
Of course, check all the easy stuff first;
check the radiator for oil scum; why is your overflow
tank low? Leaks, internal or external?
Check the gas for contamination.
Check all vacuum hoses/PCV valve for a good connections/operation.
Check the ignition wires.
Check the distro cap and rotor.
Beyond that, you'll need the experts on this site for more help
g
hard to say, but sounds like a simple ignition misfire to me, pull the plugs and see what they look like, if not sure take pictures and post.
When I step on the gas..it will have a very rough start and acceleration from 800-2000rpm then it sounds fine. ...
Are you saying that it runs fine once it accelerates higher than 2000 rpm with the truck in gear, and then resumes rough running and/or sputtering once it drops below 2000 rpm again?
g
It warms up fine and then the stuttering starts and if I try and drive engine feels as though it might just die.
WHAT would I be looking for in terms of checking the dist. cap and rotor?
I hope it is a simple ign. prob. and that is the next thing I"m checking. I will take pics and post if need be.
Yes...also, truck does not have to be in gear same applies when in N and P.
To visually check the cap and rotor, you have to unscrew the cap
and look inside; look for water, cracks, corrosion on the contacts.
Make sure all the ignition (spark plug) wires are in good condition
and that the end connectors are firmly into the distributor cap.
( I once had a rough idle after a tune up, it was just that
the mechanic had not pushed the wire all the way into the cap)
You did not mention; is your check engine (MIL) light on??
If so, you can take it to one of your local parts stores;
many of them (not all) will check the codes for you;
sometimes, they will let you check the code; very easy;
just turn the key to ON and plug the cord of the code checker
into your OBD II port on the fuse box in the dash near your left knee.
It does kinda sound like something afoot with the ignition system;
bad ignition wires, shorts, distro cap, coil, coil wire, etc,etc.
Hopefully it is not something expensive like the MAF sensor, etc.
You MAF connector is plugged in, correct? There is a specific
cleaner for electric connections made by CRC (O'Reillys usually carries it) It is not to clean the MAF, just the connector; ie: disconnect
the connector plug; spray the cleaner on both ends, let it dry
and reconnect. Sometimes just a bad connection can cause
problems; ie: just unplugging the connection and plugging
it back in can make a difference; might as well clean it.
CRC makes another cleaner specifically for the MAF (Mass Air Flow).
If the simple things do not give you any help; time for a visit
to your favorite mechanic.
Maybe some of the mechanics on this forum will have some
better ideas.
Good luck
g
Did you check your radiator for signs of oil yet? You said that the overflow reservoir was low; why?
Is the reservior full of oily scum? Any clouds of water vapor as you drive off?
What does your oil look like, any water in it?
ie: blown headgasket?
g
You said you checked all your hoses. Did this include your intake hose?
If not, check it for cracks in the pleated section...
better ideas.
Good luck
g
Great mentions...I have a scan guage monitoring my rig and there are no codes that come up. All temps and numbers are normal.
I have Electrical cleaner and will clean the recommeded items and check the plug wiring etc. as well and see what happens.
g
I did check the radiator for oil buy popping the top and looking in with a flashlight. To my knowledge it seemed normal. the neonish color of rad. fluid and clear.
Don't know why the bottle was low...probably a 10 teaspoons of murky water, but it didn't smell, look, or feel oily when I poured some onto my hand to inspect.
I did an Oil Change about 1,000 miles ago before the CON and upon checking the oil several times, it appears to be fine
I will check the intake hose, haven't done it or think of it. thank you
I can't see if there is water vapor really b/c my exhaust is shortened under the car it is cut off right after the factory muffler and the exhaust does cause moisture to collect on the rear upper control arm mount.
X2;
mine was cracked, but it just had a rough idle, as it was not
really open much; ie: when in position and all hooked up,
it will almost seal itself and can look normal, as it usually cracks on the back and bottom first. I put some glue that was laying around
and duck tape; worked until the new one came it.
Next time I will use heat resistant glue/ashesive:doh:
You need to take it off; if it is really old and dry and hasn't been
off for a few years, you can crack it just by taking it off, which is
how they get damaged; by the Gorillas that work in most repair shops.
Only about $60 to replace; almost a preventive maintenance item
at 150K miles.
Check all air/vacuum hoses real well.
G
Oops, typing to fast, too many typos and sentence fragments; my English major sister would be appalled.
I meant to say; You need to take off the intake hose to examine it for cracks.
and, you can use a heat resistant Adhesive (surrounded by duck/duct tape) for a temporary repair
until the new one comes in.
g
This also is eerily reminiscent of the wiring harness that runs down behind the EGR pipe. Have you taken a look at that one yet?
Again, upon first visual inspection might look OK, but pull it up as far as you can and try to peel back the layers of insulation and wiring a little bit to see if any of the wires are toast - melted insulation, bare wires touching bare wires, touching to ground, etc.
Dan.
I checked the intake (portion btwn the MAF and Head) very closelyand no cracks...overlooked wires and hoses in the truck until my eyes were sore...and nothing....My spark plugs were changed about 8K miles ago so they are virtually new....s. plug cables have been on since 1996...
I am going to put in an order for new cables, distributor, and rotor. First thing tomorrow morning.
ANY OTHER potentials? I'm running out of options and close to giving it to the Stealer so that she can be ready for SnT.
Thanks to everyone helping so far...keep it coming thanks
Oh and NO Check Engine light has come on both my OBDII and ScanG come up with nothing
I was thinking that too, tho mine threw a code for the specific cylinder that was having :whoops: issues...
if you haven't yet, clean the fuel pump relay. At the higher RPMs it switches to the high side so maybe the contacts on the low side are pitted.
I have had that come up and it did throw a code, but I will check it out.
Problem Solved
SOLUTION FOUND: Replaced the Distributor Cap, Rotor, and spark plug cables and now she runs just like she used to. SO glad I was patient and meticulous with checking everything...and a BIG thanks to everyones feed back and suggestions.
I had to get the parts from my local Dealer (really should be called Stealers)...paid about $40 more than a C-Dan deal, but I couldn't risk it due to time.
Thanks again
:beer::beer::beer:
