Spun Bearing
Longview, Texas
Going to take a look at a late model (80 0r 81) 40 hopefully later this week. Rig is running, but po says he knows for a fact 2F has a spun rod bearing...I think it's on the #1 cylinder. According to PO, body also has rust issues. Haven't seen, but wondering what rig like this would be worth, and would engine be worth the rebuild if that was the only issue.
Can crank be turned to fix the damage or would a new crank and all new bearings need to be installed.
Drive train of 80/40 is supposed to be in good shape. Again have not seen or driven.
Based on the body condition, I have a 74/40 with good body I could install on rig. Will a 74 body mount on to a 80 chassis or will many mods be in order?
Thanks.. dogman
depends on how badly the crank was damaged. is the guy a mechanic or has he torn the engine down, or is it just a knock or other sound that he's saying is a spun bearing? if it's spun, there's a chance that you will need a new crank...that will be pricey
i've heard the bodies can be swapped, but you'll need to modify the mounts. and i'm not sure if it would just be a matter of using the ealier mounts, or if it would be more work than that.
meat said:
'74 body will not fit on '80 frame
Bull****..
I have a 74 tub on a 79 frame. It takes a bit of massaging with the frame mounts unless you want to just run three body mounts. But it is not, by any means, impossible. The frames have the same basic dimensions, the mounts are slightly different..
You can turn the crankshaft is the motor still runs more likely than not. Or buy a Good 2F for $500ish..
Mace...did you fab up some new mounts or just modify your old mounts? Also you said " ok if you want to run on just three mounts" Doesn't sound like a good idea, but I assume from you comment that 3 of them fit ok with out mods. Which 3 are these?
I just like the idea of getting all the goodies from the later model.. 4 spd tranny and t/c, frnt disk brakes, skid plates, with the 74 tub. I assume front fenders, bezel and apron from 74 will all fit ok too.
Thanks...dogman
I thought you said you were gonna try and build up BOTH rigs.:D
That is a possibility too... Haven't actually seen the 80 model yet. Not exactly sure what kind of condition the body is in. It may be too good to think about swaping parts with the 74.
Building two rigs separately may be the thing to do. Just need to actually see 80 model to evaluate.
