Yesterday I/we started at 10:30 and finished about 3:30, swapped in a '77 front axle and installed 4 new springs. Lots of brakework left to do, but happy with progress so far.
I installed a shackle reversal about three years ago, but other than that I don't think that the front end had ever been futzed with. Well, when I removed the springs from the old front axle, there was a set of shims that looked like they have been there since day one ('66FJ40). One is marked "T 102-3", the other is not marked and they are brass. My question is...Did Toyota ever install caster correction shims from the factory? My old springs were very flat stockers. After the shackle reversal install and new tierod ends, the thing ran down the road straight with no shimmy or other front end problems. Now I'm worried as I didn't re-install the shims
The new springs are 2" lift and came originally from SOR. Some Canadian manufacturer.
I guess I'll just drive it and see. But If I DO need caster correction shims, will I need to replace the u-bolts? I know they are technically only supposed to be torqued once. I did torque them to 85#.
Whaddaya think?
Thanks,
Ed
Whaddaya think?
Thanks,
Ed
