Spring shackle pin question
Oregon
I have started to do some minor improvements to my 1964 fj40 and already find myself seeking advice.
Two bolts and one nut removed, do I just need a bigger hammer to remove this?
It's been there for 54 years; it might require some extra effort. Best results for me start with removing the large lock washer from behind the nut, reinstalling the nut to protect the threads and tapping on the nut with a BFH to get the head to pop out of the hole. Then prybars will take care of the rest.
I just went through this with a '76. Just like Mark says but I've had better luck with FreeAll or Kroil. Spray both sides, let it sit a while, spray again, whack it with the BFH, repeat.
Remove the two retaining bolts first! If they break they are easy to drill out and retap. Then remove the large nut on the back. A hand sledge did nothing on mine. I had to use a Map torch and apply enough heat to start melting the rubber bushings. Then use a pry bar and rotate the flange with huge channel locks.
Thanks... ball joint separator, hammer and some well chosen, well timed words did the trick.
Come-A-Long and large C-clamp for reassembly.
Thank you!
Torch. Air hammer. I used a spade drill bit to easily get the bushing out.
I was putting on new pins and shackles so I didnt worry about damage.
Yeah I'm wondering if the pin survived and is reusable. OH yeah, there it is in the photo looking fine. I've had a horrible time getting mine out in the past. Heat and whacking on it half separated the pin from the head/flange and completely distorted it.
I think the other secret is to get the spring, eye, and pin into the most neutral position as possible. Any pressure on the parts make them more difficult to remove. Removing all outside stress on the parts allows you to concentrate on the rust that is keeping them together.
Yes, I put jack stands on the frame and floor jacked any tension off of the pins, they slid out by hand after the initial hammer work. Good advice. Reused the original metal.
Cut mine out with a grinder, was replacing them anyways. Not a fun job, but my ride was much improved afterwards.
