Spring info
up there somewhere
I'm planning to replace my springs and I have a couple of questions. First this is what I have now from the PO. Stock springs front and rear with 2 1/2 in. lift shackles in front and 3 1/2 in. shackles in the rear. I'm going to use OME 1 in. lift springs in front with 1 1/2 in. shackles and 2 in. springs in the rear with 1 1/2 in shackles and Energy Suspension poly. bushings all the way around. This should give me approx., the same ride height and stance that I have now.
My questions are :
1) I have read several posts stating problems with axle position after replacing springs, is this a valid issue or just someone's bad luck? I plan to follow the FSM procedure for replacement, this seems like it will insure proper axle placement, am I correct in this assumption?
2) How important are the correction shims, I don't have any installed now and I'm not experiencing any steering issues or tire wear.
I have a SBC engine and NV4500 trans with no radical driveline angles.
3) the OME springs have friction pads between the leaves and are supposed to be greaseable, what is the best way to accomplish this and what is the recommended grease to use?
Any input is appreciated, Thanks in advance, CAJ
Sorry, I don't have any answers for you as I am new to 40's but I had a question, where did you find 1" OME lift springs, and do you have a link? Id like to replace my springs with the smallest lift springs I can find since I can't find factory height replacements.
My questions are :
Any time you move the axle up or down (which is what lift springs do), you change the axle rotation a little bit. The higher the lift, the more it will change. Shackle lifts will change the axle rotation much more, because you are only moving one end of the spring. The rotation of the axle around it's long axis will change the steering caster on the front and will change the driveshaft working angles on both front and rear. So yes, it is a valid issue and not just bad luck.
Correction shims are very important, if your steering caster is off on the front axle, and/or the working angles on the rear u-joints get out of whack. There is no way to say or tell you; you must measure your steering caster and the working angles on your rear u-joints after the new springs and shackles are installed. Only then will you know how much to shim the front or back. But you will know if you need them, if your steering catches every little bump and groove in the pavement, and if you get driveline vibrations/shudder at certain road speeds.
The # is EMU CS001F. Available from several vendors. I bought mine from Summit Racing because of free shipping and a good supplier.
The axle position I'm referring to is the forward/rearward position of the axle. The poster stated that the wheels were no longer centered in the w/wells. If the perch is in the spring pin how can this happen?
Man-A-Fre was purchased by BTB in Vegas, I believe. I wonder who is making their springs now (those show backordered). @lcwizard might know. But I'd be leery without knowing more since the company has gone though a change of hands.
@coonassjohn, this is typical of most, if not all manufactured lift springs for the FJ40. When the springs are in the "rested" position. As the suspension moves through its cycle, the wheels/axle will move more towards the center of the wheel well.
I seem to recall that the pads are a type of lubrication themselves. Inpragnated with teflon or graphite or something like that. I heard of folks taking the springs apart and paint them with graphite paint. I just grease the bushing periodically.
yes, the good ones are impregnated with PTFE or graphite. That doesn't mean that all are.
Best just to replace them if you're unsure or they're worn. Ebay, Summit, Skyjacker, Dorman, most any spring manufacturer
will carry them. The variances are width and locating pin dimension.
If you're taking apart the pack one trick to add to the pack that reduces friction is adding 4" x 2 1/2" 16G shims between each leaf
at the center pin. You'll obviously need a hole in the center of each shim to pass the center bolt. Between the shim in the middle and the pads at the end of each leaf , friction is reduces dramatically
Hi, wondering what the 4" x 2 1/2" 16G shims are that you mention above. My Skyjacker softride 4" springs have the pads between each leaf at the ends but nothing between the leafs at the center pin location. I like the idea of less friction but need a bit more info on these pads and where to buy them (or make them from material stock).
Thanks
That would be 16 gauge thick shims. Small spacers between the center of each leaf. It just allows each leaf to move more freely rather than dragging on each other along the entire length. You won’t see them in any production leaf pack, more of a custom trick.
