spring flip ?
West Georgia
i'm in the process of a soa on my '74 fj40 and am also planning on flipping my springs around to get a better approach angle and longer driveshafts....my question is does it matter if the military wrap end on the spring is pointed to the wrong end now? (hope this makes sense) do have to drill new holes in them or can i just go with it and be okay? this is to be a trail only rig....thanks :confused:
It only matters if you break the main leaf, which happens on hard trails and is why there is a military wrap back up. Most people prefer to flip the leaf and drill a new hole. A carbide end mill or a masonary bit will drill it.
If you do a shackle reversal on the front (which i highly recomend) at the same time as the SOA the wrap will already be on the front/short end of the spring. However if you flip the rear springs so that the short end is towards the rear you will have to flip the second leaf so that the wrap will stay on the frame end of the spring.
flip the second spring and redrill..
Naw, I break s*** so it "looks" like I am hardcore....
excuse me for the stupidity, but wouldn't it be better to flip the spring without the shackle reverse, because having the long side of the spring chassis mounted with appropriate length shackles, shouldn't this give alot more travel than having the short side solid mounted?
nuclearlemon said:
redrilling just gives it a weak point to break at :D
It also gives the center pin a place to go through the spring pack.
The shackle reversal alows you to get the "appropriate length shackles" behind the axle and not hanging down in front of it to catch rocks. I agree that you would probably get a little more flex that way but I dont think it would be worth it.
mookie said:
i guess what i don't understand is why it matters if it's on the frame end or the shackle end?
there is significantly more force on the spring at the frame end because it is a fixed point and not alowed to move like the shackle end. This makes iot more likely for that end of the spring to break.
too tall said:
you actually get more flex from having the long end of the spring being the shackled end.
Please explain how that works.....
I have seen/heard of more people breaking the main leaf from torque than breaking springs due to an extra hole.
Typically the 2nd hole is still under the U bolt plate and does not move.
I have yet to hear of a spring that broke because of a redrill on the center pin..
If you have proof otherwise I would love to hear it.
:D
well alright i'm convinced, i guess i'm commiting 8 hours or so of my life and a bunch of drill bits to drilling new holes....i'm not doing a shackle reversel, i've already had my housing cut and turned and didn't take that into account....planning on adding a mild add-a-leaf (from maf), spring flip, take out the smallest leaf, and stock shackles, i've already got a 2" body lift, plus the add-a-leaf plus the soa should give me enough clearance for the 38's? anyone tried this setup or have any further beta? i've based my soa info pretty heavily on the tech section write-up by Andre Shoumatoff...yeah! the dude wielding the big freaking torch!
Rascall burned through 2 leaves in less than an hour using some good drill bilts and grease.
I was suprised at how quickly he did it.
And Pee, you are a freak :flipoff2:
I also did both of mine in less than an hour with my HF drill press set at 200 rpms, HF drill bit, and lots of cutting oil. The key is slow rpms and cutting oil to keep the bit as cool as possible.
