- Thread starter
- #21
Never as much as I'd like - since the shutdown ended its been pretty non-stop catch-up at work. But I did get the chance to swing by the garage and pull the heater. I think I'm just about good to go to pull the body off, once I pull the front clip too and remove the steering column. I also pulled the wiring harnesses, there's so many random crimps, splits etc that I'm just gonna try to make a fresh one with the old stuff as a reference. That should really clean things up under the dash since I have the samurai harness + tracker EFI harness. That will be...fun?You had any more time on the Sammy project?
I don't know if I mentioned this here, but I got a Harbor Freight cherry picker to help pull the body. Once that's up I plan to roll the chassis out from under the vehicle, and then set the body on a wooden frame so I can work on welding up the tub.
Fortunately it's not too cold in the garage, even though it was about 18 degrees outside. I'm really glad that the Sami is inside for the winter- this time last year, I just had to wait until spring to uncover the car.
