spindle issues
Sandy Utah area
So a few weeks ago i had a wobble develop and I found my PS front wheel was loose. I took it apart and found the inner hub bearing was worn so I replaced both bearings, races and the seal (timken bearings)
What I found was that the spindle has been damaged and looks pretty chewed up. I did my best to measure and the best I got was a 5 to 7 thousands difference in diameter. you can feel a ridge with your hand. The wobble is gone and the bearings are set again but I have a feeling this is going to need to be replaced. thoughts?
Loctite or 3m (I forget who) makes some goo similar to thread locker/sealant exactly for this sort of thing. It is called bearing compound or something along those lines. Sorry, I'm on my phone and don't feel like trying to google...
Looks like Locktite retaining compound, but I can't decide what its meant for, It looks like its a seal for shrink to fit bearings.
It supposed to be used on shafts that are worn or not sized properly.
Another option is to get new spindles.
I believe cruiserparts.net sells some a little cheaper than the dealers. They are not OE, but are machined to spec by a very reputable company in Japan called Joint Fuji
If the bearing preload is correct, the inner bearing race will NOT move on the spindle, so no additional wear should occur. The only thing that is supposed to move is just the roller bearings. The races are supposed to be fixed positions. John
Another fix might be to "stake" the spindle tubes where the wear develops. Did this to my spindles five years ago figuring it would be a short term fix but the bearings are still holding their preload 45,000 miles later. FWIW.
