First time post.
I have a (new to me) 1969 FJ40. Speedo doesn’t work. While changing the rear oil seal I discovered the Speedo cable to the transfer case is broken, apparently because the speed marker is frozen. How can I check to see if the shaft gearing, transfer case to the cable, is working without disassembling the unit? I have a 6” tail piece of cable still connected to the transfer case. Since the rear shaft is not in the car, is it reasonable to put the truck in a froward gear at some low rpms and observe the cable? I am considering a Dakota Digital dash so this is critical. Thanks
