Got a 2003 LC. Speedometer stopped working. Replaced the vehicle/transmission sensor...didnt work. Replaced the ABS speed sensor....didnt work. Any other ideas?
Just checked. Reverse lights are working.I'm not entirely sure this will be helpful, but...do your reverse lights work? They share a fuse with the speedo. If you've done any work around that, or maybe have an aftermarket trailer harness—whatever would cause that fuse to blow might be worth the 5 minutes to check it out.
The particular fuse is behind the PS kick panel, I believe.
Looks like thats what i have to do. Is getting to the connector for the cluster difficult?After you've confirmed the fuses and such are good, @planomateo probably has the answer. I had the same problem, did the same 'repair' by swapping the VSS. Nothing. I needed to partially remove and securely re-connect the cluster. Worked great after that.
Any feedback is much appreciated!!Just as I suspected...I'm not that helpful!
This just recently solved my Speedo not working on cold mornings. The other conditions I had were no Cruise Control.After you've confirmed the fuses and such are good, @planomateo probably has the answer. I had the same problem, did the same 'repair' by swapping the VSS. Nothing. I needed to partially remove and securely re-connect the cluster. Worked great after that.
I was hoping to avoid this "cluster", but will bite the bullet. Hopefully I won't break anything in this operation.This just recently solved my Speedo not working on cold mornings. The other conditions I had were no Cruise Control.
Its pretty simple, disconnect battery, pull the trim pieces on the side of the steering wheel, pull airbag (disconnect), remove steering wheel (be sure and mark orientation), then remove the bottom trim piece (pull straight out or pry with trim tool), disconnect dimmer switch dial. Then remove 2 trim screws at the top. then you will have 2 black trim screws at the bottom corners of the cluster and the 2 large screws to disconnect the cluster wiring harness itself. This is a good time to replace any burned out bulbs. Prior to replacing the cluster make sure the harnesses are attached to the plastic. When replacing the cluster the large screws will tighten until they spin freely (they will click), they do not stop spinning. Here is a shot of the harnesses.I was hoping to avoid this "cluster", but will bite the bullet. Hopefully I won't break anything in this operation.
Bonus: gives me a chance to replace steering wheel extension motor.
That is way too deep for my pay scale. I just know I would be breaking other things.Its pretty simple, disconnect battery, pull the trim pieces on the side of the steering wheel, pull airbag (disconnect), remove steering wheel (be sure and mark orientation), then remove the bottom trim piece (pull straight out or pry with trim tool), disconnect dimmer switch dial. Then remove 2 trim screws at the top. then you will have 2 black trim screws at the bottom corners of the cluster and the 2 large screws to disconnect the cluster wiring harness itself. This is a good time to replace any burned out bulbs. Prior to replacing the cluster make sure the harnesses are attached to the plastic. When replacing the cluster the large screws will tighten until they spin freely (they will click), they do not stop spinning. Here is a shot of the harnesses.
back of the cluster
Issue is you can’t pull the cluster out without removing steering wheel. Here’s a hint though:That is way too deep for my pay scale. I just know I would be breaking other things.
There is a video reference in this forum that a) does not require steering wheel removal, b) cluster connector screw tightening while moving (too make sure that is cause).
If that fails, the stepper motor is next. 'Course coudl live with the smart phone/OBD work around.
forum.ih8mud.com
It could work. For my LX, wheel didn’t drop enough out of the way.This just came across showing stearing wheel remaining in place:
LED instrument panel/gauge cluster
After viewing Loud's LED thread, I had the urge to update most of the the bulbs behind my gauges to LEDs. No more dull lookin' gauges at night. Bulbs replaced were the speedometer, tach, fuel, water, oil, and battery. Gear shift indicators, turn signals, and brights were updated as well...forum.ih8mud.com
Am I missing something?
