Spark plugs hard to remove
hillbilly desert rat
I tried to remove the spark plugs for the 3fe engine... those things are so tight I am afraid of them breaking or stripping while removing them... A few of them will loosen like they should only to get tighter as they come out of the threads... OH MY ...... Any suggestions on getting the plugs out without the pucker factor? #1 plug is tight the whole way out (or as far as I was willing to torque on it) that one really scares me.. I put them in so I am sure they went in like they should have... AAAAAAAAAAAARRRRRRRRRRRRRGGGGGGGGGGG
For those plugs that have partially loosened only to get tight again I would spray some lube or light oil down to the threads as much as possible and start to tighten them back in. If they are not galled they should start to free up. Keep applying the lube and working them farther in and out. If they start to tighten up reverse the direction.
On those you can't break loose, apply some penetrating oil and let then sit as long as you can. As carefully and evenly apply pressure keeping the wrench from slipping. If they still don't break loose then try applying pressure in quick bursts or by hitting the wrench with the palm or your hand. The best type of wrench to use would be one that a rod slips through and you can place a hand on each side.
The cause is from someone in the past putting anti-seize on the threads. Then when the engine gets hot the anti-seize gets dry and turns into pretty much a metal based loctite. I almost had to remove a head on my land rover discovery because of this but was able to save the threads after about 3 hours of work and two different thread taps.
As far as getting the old plugs out I've had good luck with PB Blaster. Make sure to to clean the threads well before the new plugs go in and install the new plugs dry or with a few drops of engine oil. Bosch and NGK plugs have a coating on the threads from the factory and don't need any oil with the install.
Also are you trying to do this on a cold engine? Sometimes trying on a warm engine can help. Definitely no copper based antiseize compounds on an aluminum head. Just use a dab of grease or nothing at all.
Oh man, I know exactly how that goes. And I know the joys of having one snap off in the head. Stupid Ford truck...
Loosen until they get tight, spray, tighten back in, loosen, spray, etc etc etc.
I find it often easier on a warm engine also. We have used silver anti seize on gas turbine engines without problems. However it's never on steel/aluminum stuff.
The lubricant mostly used was engine oil mixed with dry moly lube. Which worked great on alot ofthe fasteners that took alot of heat.
I prefer antiseize, however I never had a problem with plugs on vehicles I own. Maybe I'm lucky. Also I like to check my plugs once in awhile to see how my engine is running.
I was reading in Popular Mechanics about those 100k plugs that car manufactures advertised on their cars 12+ years ago. People were having problems with the plugs being seized and sometimes "welded" to the heads after 9+ years.
This. If a cylinder is running lean that could definitely happen. I don't care what anyone says, I'm changing my plugs every five years tops.
i have had this car for a long time... there is no seize stuff on them ever... maybe i will try to change them on a warm engine.... I have broken a plug off on a 22re engine... i put some PB Blaster on there and used a pair of needle nose pliers to remove it... LUCKY DUCK....
hopefuly I can get time to get this done across the weekend
Here is some info from the spark plug maker NGK, pre their recommendations, if the spark plugs metal shell has plating on it, then no anti seize is needed. If the metal spark plug shell is just a "plane" un plated shell, then it needs anti seize.
http://www.jagrepair.com/images/AutoRepairPhotos/NGK_TB-0630111antisieze.pdf
Now if you want to use a really good spark plug anti seize, you could try the stuff we use to use on aircraft engines. Its a little different then regular anti seize, it contains A high-temperature, graphite lubricant, so it's not thick, and greasy like the anti seize you get at the auto parts stores.
ATS2612 SPARK PLUG THREAD LUBRICANT from Aircraft Spruce
The trick is to soak each plug with PB blaster (or other lubricant) and go SLOWLY! DO NOT try to back them out in one continuous attempt.
As soon as you feel the plug getting tight...STOP! Respray with lubricant and let it sit for at least an hour. A lot of heat is generated from the friction of the two parts (plug threads against threads in head). It will do no good to just keep cranking on the plug once you feel resistance.
I also don't like to run the plug back IN the head, we aren't 'tapping' a thread here and any 'extra' friction/movement is not wanted or needed.
Take your time! At first you'll probably only get about 1/4 turn each time you try to back a plug out. That's fine. Just respray, let it cool down and go back to it. Eventually....you'll get 1/2 a turn, then reach a point where you can tell its OK to back it out the rest of the way. Expect it to feel 'heavy' the entire way out.
Some say not to use antiseize. I will leave that up to you....but I've used it for many years with no issues. Do not over-tighten the new plugs when installing them. Then.....check your plugs periodically. Don't leave them in there 8-10 years and expect them to just back right out....as many folks seem to do.
One last thing.....DO NOT back the plugs out to the point where your feel them 'chatter' or the feel across your ratchet gets 'mushy'. If you do...you'll probably be putting a helicoil in your head. Go slow.
SOMETIMES, it can be caused by corrosion on an engine that has sat a long time and had moisture in the cylinders and rusted the threads on the tip of the plug.
Other times, it can be carbon buildup due to an engine burning lots of oil and the carbon is binding in the threads on the way out.
I agree with most of PB blast, turn out, then in, then out, spray, then in, out lube, in, out lube..............
I'm pretty sure you understand the lube, out, lube, in part.........:D
