source for stainless bolts
Cruiserhaven said:
Does anyone have a good source for stainless bolts (buying non-bulk)?
TIA.
All of my stainless has come from McMaster-Carr (http://www.mcmcaster.com). I think, all things relative (Lowes, et al), they are reasonable.
local mom and pop hardware store is where I get mine
I can't remember if it's SOR or somebody else who has a full SS bolt body kit. It will probably save you money if you don't have any yet. I did from the PO so I am slowly buying SS bolts as I work on different parts...
Remember there are more bolts that can benefit from being changed to stainless than just those on the visible body. E.g. the bolts holding the skidplates onto the frame...
B
stainless
Fastenall has a good supply of SS - if not they can have it for you in 2 days. I just took a sample of each bolt and ordered a whole bag of each. Tractor Supply has a pretty good supply as doe't most NAPPA stores.
Fastenal here too. Shipping was fast to the local hub/store. Prices were great, around one fourth to one third of the prices at my local hd/or lowes. And the variety they had, if you needed an M8x1.25, you had your choice of length in increments of 5 or 10 mm from 15 to 130, so you could match precisely all the bolts in your truck. Every bolt for my restoration cost me around $250 to $300. Every single bolt I took out of my truck except for where I needed grade 8 was stainless. Very affordable to do, and very worthwhile.
Just don't use stainless nuts on stainless bolts, especially when you get into larger sizes such as 3/8" and up they gall on each other and you'll regret it. not such a problem on the fj with captive fasteners, but it comes up
Question - are 18-8 stainless bolts strong enough for body mount applications, or would I be better off going with a zinc plated grade 8 (how does 18-8 stainless compare to regular grade 8)?
captive nuts are the floating nuts in the little cage that allows some movement or alignment of body parts, I think
I did get a sor kit for my fj45 build last winter. It included quite a lot of screws, bolts and washers but wasn't cheap. I think it was about 70 dollars
