Sound Dampening
Corvallis, OR
So in my 92,
I want to upgrade my audio setup, but one of my concerns is the sounds of the road and wind outside of the car interfering with the sound of any music I might be playing. I think there is a way to install sound dampening pads or material under all of the Cruiser's panels to reduce the sound, but how effective is it? Any more feedback I could get on this? Thanks in advance...
So in my 92,
As someone who doesn't care either way, I've ridden in cruisers that have it (dampening material) and ones that don't. I didn't hear much, if any difference. Pretty sure one of them was also sporting new weather stripping and all that crap.
:meh:
I did find it interesting that my buddy said there was less road noise in the cabin of my rig, with 37" mud tires and blah blah blah done to it, than his wife's scion which is only a couple years old. So I guess I've got that going for me, which is nice.
In my opinion, vehicles are not the place for audiophiles; I have a nice pair of Sennheisers and access to raw, vinyl, etc. recordings if I want to do that. Music in vehicles is to provide you some background entertainment while you travel to your destination. Going all out for a sound system that 'bumps' or whatever is to make you more of an a-hole when the weather is nice enough to have the windows down.
The only time I've ever cranked the music loud enough for others to hear was Mahler 2 at the conclusion of driving through an amazing canyon in Utah back in March and that blew one of the 19 year old speakers out, so I guess I learned that lesson.
I haven't road tested my new insulation yet but there is a night and day difference in the sound quality from the door speakers after insulating them. More info in my build thread.
:meh:
That's a good perspective. The level of noise (noise floor) that you have to deal with in a 20 yr/old truck with big tires is pretty high compared to a modern luxury car. I think putting a modest effort & budget into the stereo and sound deadening makes good sense for most of us on here.
I've found turning up the volume helps with road noise(s). Just installed a 5 channel 1200 watt amp, which really helped. Plug and play
so far I have done dynamat on the doors and side panels of truck, working on doing dynamat and a foam layer. Dynamat will help with resonance but you need something else to help absorb the actual noise, which is where carpeting and / or foam comes in.
FWIW, the result of doing the doors made my cabin much quiter overall and gives a great solid feeling when closing the doors.
Thanks for the feedback!! Now, I'm questioning you're location? Haha
removing stock roofrack was first and most noteable improvement.
second most noticeable was doing all doors and side panels especially over wheelwells on cargo area. (dynamat type)
thirdly - did floors with lizard skin from firewall back under carpet. (gallon of goo)
lastly did the roof with lizard skin ceramic spray. noticed a ton of heat transfer prevention on hot days baking in the sun. less so on noise.
overall- 37"mts sound alot less noisey than stock friends rigs.
eliminating rattles on interior will also go a long way to making your travels a bit more pleasant. while its not quiet like my Lexus Ls400.......i can pretty much equally hear tires/ wind / and catless exhaust growl........so overall very pleasant reduction in noise ceiling while still being aware of rigs engine/feedback.
So in my 92,
So, i had the same thoughts. The first thing I did was replace window rails. I think I paid $ 240 for all 4. This is the upside U shaped gasket that the glass windows ride up and down in. I stressed about replacing them, finally had a shop do it that knows cruisers. There estimate was $ 850, and they charged $130 after it was done, stating that on some of the 80's, they are able to slide the new rubber in, without disassembling the door.
Best money I ever spent. Totally quieted up the truck. No need to sound dampen now.
The second best money spent on the rig was all new rubber underneath. Motor mounts, tranny/transfer case mounts, tie rod ends, all bushings.
Rides like a dream !
Good luck !
