cabron said:One question... Are products like DynaMat prone to holding water/moisture? Just wondering about inside the rear quarters and doors if moisture could get trapped and lead to rusting any faster?
Only if the metal is wet when you put it on. Make absolutely sure the surface is clean and dry, put the stuff on warm so you cna work with it easier, and make sure there aren't any bubbles or wrinkles that could let air and moisture underneath. If you do all that you won't have any problems with it.
