Something grinding
I was just driving along, had been driving for about 5-10 minutes around town. I went into 4th one time and was driving, id say about 10 seconds, then this grinding sound, real loud too started and the car started shaking. it lasted about 3-5 seconds or a little longer then quit. About 100 feet later it started it again, in 2nd gear when i was going into 3rd. I wasnt driving it hard or anything, if anything at all i was driving it as smooth as possible....So wierd. Any guesses as to what is causing this? I looked under it after and it was putting off a little smoke. Ill post the picture in the next post
Is it in the rear or the front?
I had the little brass "oil dripper" come off, and get ground around by the timing gear. After it popped out on top, it was quiet. The grinding took about 10-20 seconds. Then it was quiet except foe a real light "ticking" as the gear and the brass nozzle would rub each other.
Anyway - that's what made my grinding noise. I'm not sure that this is the same..
Good Luck
Rocky
PS. I'll give you $500 for your truck - even with the grinding noise - sight unseen (Actually - I saw the pictures in your other post...). It's a nice cruiser!
I found the problem, believe or it not. My dad drove it earlier in the day and he didnt put the e-brake all the way down...and i think its worth well over 500 dollars, but thanks for the offer. Dont know if you were looking at the right one or typo'd...
