I'll just start by saying that I know little (if anything) about trucks. I'm trying to learn as I go.
So here's my problem:
The last two times I drove my Cruiser, I made it about 100 feet, then heard and felt a horrible grinding noise coming from the rear end. The noise isn't constant, it just comes and goes randomly.
This morning, I removed the differential oil filler plug to check the oil level. The level was fine, but there were metal shavings everywhere. I know that's not a good sign, but to make sure that's my noise making problem, could I remove the drive shaft and put the truck in 4high? Then, it would basically be front wheel drive.
Has anyone had this problem? Would you advise me to try this FWD thing? It was recommended to me from the PO.
Thanks a lot for any help.
Mike
Mike
