Soliciting Opinions>>>>>>>>>
upstate NY
So, my son borrows my 97 40th Ed, that I bought back in March of this year..... I drove it for 4 months, never any problem, (261000 miles), I get it back from him, and the rear pinion seal begins to piss all over the driveway. he says he never took it 'off road'. Do they normally fail catastrophically like that? in my opinion, a seal is a gradual leak. if you pay attention to your vehicle, you notice but when it gets bad you fix it. but this happened in 1 day. by the way he said it was a champ going into the camp he was working at.....
Age of vehicle, hard and brittle rubber gaskets, if I were him......
I would have hammered the snot out of the truck but I am sure he is telling the truth.
Great time to replace every seal you come to in the tear down site. I have had both experiences (short catastrophic failure and the long drawn out rustproofing).
He is a good kid, buy him one of his own!
I would say it just went, Even if he was hamming on the thing, I don't see it causing the seal to go out. If he did not take it out for a quick Romp I would be disappointed. Boys will be Boys !!!!!!!!!!!!!!!!
Seals fail, and those probably are more likely to fail from thermal cycling (long freeway runs etc) than impact.
One exception is if the pinion is loose from ABSOLUTELY thrashing the thing and now it's wobbling around in the seal. I doubt it tho.
Got trust issues with your kid?
Not your son's fault. Road use vs. off-road use wouldn't make any particular difference, it's just a piece of rubber that got worn out after 25 years.
My pinion seal on my 18 wheeler started pissing oil on the way back from Alaska this last time. Light load no abuse! Also had that happen in winter when the breather tube got clogged/frozen
Check breather tube and hose. If he had it on the highway and got it good and hot, it could have forced a leak.
Even more so, if it was good and hot, then he dunked it into a river or deep puddle, the quick cooling of the water would quickly reduce temperature and if the breather is clogged, it can suck water in through the seals, causing contamination of oils.
Teachable moment. You break it, you fix it. Its called "life". Put him to work. At least make him help you fix it.
