Softop window cleaner???
Seattle
Website
www.seattlecruiserheads.com
The rear window of my softop is so discolored and hazy I can barely see out of it. I have cleaned it with basic kitchen soap and water but the white haze film still remains.
Anyone have a good cleaner that will get the window "glass" clear again?
Thanks,
Max
Go grab your Spray Pledge Lemon Furniture Polish. You will be shocked how well it works. Just like the fancy plastic polish, just cheaper.
Jack
I remember someone telling me once that petrol vapor will discolour some types of the clear window materials. Soft tops have evolved somewhat and they are generally made with better materials these days but its probably a good idea not to carry a jerry can inside the soft top or have a leaky tank for this reason (among others!).
Don't know about cleaning them though but thought I'd pass that on.
Lup:)
Hey Max,
Try Meguiars Clear Plastic Cleaner and/or Clear Plastic Polish. I haven't specifically used them on softtop windows, but have had great results with them on hard plastic gauge lenses at work.
Of course, test them out on an inconspicuous portion of the window first, to see if you like the results. :grinpimp:
Schucks, Autozone, and similar places usually carry them.
Todd.
Go to your local marina store, they have good polish for the windows.
3M MICRO CUT and then 3M FINESSE polish.
this stuff too....is very good :) i can't remember if it were micro cut....but...3m is really good
Most compaounds have an abrasive..this BAD of soft top windows.
Micro cut has NO abrasives .
it must have been the micro cut then...it was many moons ago (1986) in H.S. when i had my triumph spitfire soft top...i did remember it was 3m and the local marina guy thats all he said he would ever use!
Micro cut was not on the market then.............;) But they had light and heavy cut. Sand or gravel was your choice:eek:
technicaly the micro cut is an abrasive... This is just like buf clear coat.. polyurethane clear coat IS plastic. Seriously.. as long as you start high and work your way down it'll be great.. IE cutting compound then polising compound then a hand glaze. they'll look great.
Is it best to use these products with a hand cloth or a power oribital buffer etc???
Cloth diaper is the best. get it damp and aply product to cloth and rub in circles. Tape off the black edges with blue masking take or you will have white edges wher you over lap.
Shane
