so, this 80 I bought for cheap doesn't have a horn...
Just left of hood latch one wire grounds through the horn mounting bracket.
You need the horns off a Mercedes 600 Grosser. O'le Jezza Clarkson 'got kicked out of London' when he set one of those off in a parking garage. lol
Get a Nathan’s Air Chime Air Horn set-up, and the next “red light reader” you are stuck behind will go into cardiac arrest when you lay on them!
I am running full size American luxury sedan horns mounted on OEM Toyota brackets. Fit well and sound much better than the originals. Cost me $5 at PicknPull.
How did you fit those in front of the radiator? I got a new horn and I am having trouble fitting it where I can connect the wiring to it
Do you have a pic how the horn wire connects to pad? I'm putting factory wheel back in after taking off the Nardi wood wheel. I see the wire but not where it connects.
Ya all just need to slow down🤪
The LS400 horns are also plug and play and mount right up in the OEM spot.
Much louder without being obnoxious😉
This is the ultimate solution I found for my rig.
Electric air horn.
Also has a PA function. So when the horn isn’t sufficient, your can just yell at them.
Putting the factory wheel back in my 96 80. Turns out the wheel is for newer landcruisers with the horn wire connected to a harness. The landcruiser has the older style brass pin. So I poached the horn ring off the nardi wheel. But realized the ring touching the metal of the wheel caused it to ground out. So i think if I insulate the ring with electrical tape it should work with the button.
