So my centered axle isn't centered...
Morgan Hill, CA
Website
www.pirate4x4.com
Just something I hadn't thought much about before... its obvious that the pinion on a toyota 3rd member isn't centered, just as its obvious that their mini truck rear axle housings are centered. So, the pinion is going to be a bit off center. I was still a little surprised to see how dramatic the offset is when you bolt up your short (25") rear driveshaft to a truely-centered Xfer case output shaft.
(the angle is exaggerated slightly since I wasn't lined up with the center of the vehicle when I took the photo)
Now that I see it, I'm wondering if the Xfer case output was off-center on my previous wheeler (88 4Runner) or if it was just much less obvious because the rear driveshaft on that vehicle was around twice as long.
So you guys running centered rear axles... whats your experience with this? Did you off set your drivetrain so the Xfer is in line with the pinion? Are you getting driveline vibes if you didn't?
I don't expect it to be an issue for me... this truck won't see much freeway driving, if any at all. I'm just curious what others have run into.
the truck articulates 60".....
bias tires that have never been air'd over 10 psi....
unbalanced beadlock rims....
it gets flopped and rolled...a lot....seriously, a lot....
driveability issues because of a rear diff that's slightly offset is WAY down my worry list...lol
that said, it does 55ish comfortably....thru town it's great to drive...
swilson said:
Is that a high pinion 9"? Looks great.
Yes it is, and thank you! :beer:
swilson said:
Also looks like the housing puts the 3rd member off center. Are your axle shafts different lengths?
I requested when Sunray built the housing that the pinion of the diff be in the center of the axle housing, which by doing so, makes one axle longer than the other.....It is a full floater that now runs CTM 300M axle shafts to Chromo drive slugs.....
:beer:
swilson said:
And what is the yellow cover on your 3rd member?
It is a little shield that I made to provide protection to the bulkhead fitting and air line connection in the diff housing for the ARB. The fill plug for the diff is also behind that. It is .250" steel welded together, and can be removed without touching the bolts that secure the diff to the housing or the pinion bearing support.
The real trick piece of the rear axle however is the custom skid plate that was made for me. The guy is one hell of a fabricator. This thing has been USED over the last year and has not so much as even coughed. You are the man Trip! :beer:
peesalot said:
that driver side spring pack has some nice curves in it.
Ouch!:eek:
Steve loves it when people compliment his member :D
OME spring packs have a flat spot in them where the axle perch rests on the pack....
You going to PM me your addy for that 420 stuff?
swilson said:
OP??? I'm guessing you're talking to me, since my photo is off center... the FJ40 is level, the camera angle just makes it look unlevel.
OP- Original Poster....
What engine is in this truck?
Land Cruiser 6, small block Chev, or ????
