So I want an FJ 40 but...
Madison, MS
***Disclaimer***
If you're a FJ 40 purest DONT READ BELOW!!
***END DISCLAIMER***
So I have really fallen in love with these FJ 40's and I have grown to love the shape, well almost. I've always been a Jeep guy more so than a Toyota guy. The more I look at pictures the more I wanted one. The problem was they were either in really bad shape and wanted top dollar or they were in really great shape and wanted top dollar, a kidney, left testicle, a lunch and while they were at it the other kidney. Honestly for what I wanted to do with it neither of these options worked for me. Well, they could have worked but what fun would that have been. So I happen to have a friend that bought an FJ 40 that I could pull some measurements from. After spending a little time measuring and researching, boy that thing was JACKED UP. It was a real struggle trying to pull anything constant from this FJ. However for what I was doing, it will work.
So the first step was to order some cold rolled sheet metal. I ordered some 16 and 18 ga sheet metal, about 10 sheets each. Then I went to the computer and try to draw the basic shapes. With my rough measurements I can cut some blanks to get started with.
So my thought was I would start with the smaller pieces. I started with the inner fenders on the back.
So now I needed to make a die for my Pullmax so I can make the same shape as the FJ40 upper body edge. I think it turned out pretty good.
I'm interested
There is always a two step process on making a panel. The next part of this equation is to make a guide so I can run that die over edge of the panel.
I guess I should have stated my plans first. I have a 6.0 Chevy engine that I'm going to put in this with a Dana 60 front and 14 bolt. I already have them built with Detroit lockers chromoly shafts and OX joints. I also already have the DOM tubing for the tube chassis. I want it to look the FJ40 part (kinda) but I want a rock crawler. I also Have my Corbeu seats already. The picture is what I'm aiming for. Also, sorry it takes so long to post, I'm doing it with an iPhone.
Front cowl section I cut. As you see I have the slot for the louvers. Well, crap I don't have a louver punch... Let's make one.
Basically I wanted a louver tool that I could cut any length louver. I'll just post the pictures. Basically I take a chuck of steel and face the pieces and then put on the index table and machine the shape into the edge with a ball end mill.
Dang picture limit...
So, fast forward...
Typically you make a few passes first cutting the metal then pressing the shape in. I used a short cut by cutting the 1/16" slit on the CNC.
So let's test this out...
Ok, so it works better than I thought and it's very similar to the louver cutter that you could buy in the 50-60's.
Let's actually use it.
Damn, man.
You have some major skills, and some awesome tools.
This is gonna be good!
I haven't 100% decided what to do with the vent hole on the front cowl piece. To me, it's an iconic piece that really defines the FJ40. On the other hand it's a vent and I don't know that I actually need it. So for now, I will leave that unfinished so I can either delete or do something cool/different. I did however leave enough meet to form what ever I want to form there, meaning the stock shape.
Here is basicly the "rear" comp cut sections. So I made another hammer form so I can fold the lip on the fender down and it served another purpose to be a guide for the edge die. In one of these pictures you can see the MDF under the sheet metal. I was in the process of removing it.
