Sniper in tank pump help
Oregon
For the Holly Sniper 2300, what is the best in tank fuel pump setup? Any recommendations? Going to be running in on a late model - fuel take above the rear axel, not in the cab.
I use Denso/ OEM Toyota pumps. Any of them from any 90's - newer EFI Toyota will be great, compact and reliable.
@cruisermatt do you know of any Toyota kits that include the hanger and pump that fit our application?
I just meant the pump itself - simply use one of the available retrofit kits, Mosely Motors, Redline, Down-ey, or mine and use a Toyota pump instead of the Walbro hot garbage
Mosley sells a very slick Denso kit. Very little fab skills needed to install. Only have to cut a hole and make 2 tack welds.
Highly recommend.
@wngrog Good to know. Have you used one in any of your recent builds? I'd like to see the install.
