An easy field test to see if within factory spec snap ring to hub flange gap of less than 0.20mm, is to: Grab outer tulip of front drive shaft (AKA: FDS, AKA: CV). Pull and push. If you see gap change between metal shield of FDS seal and steering knuckle, gap is to wide.
This picture just happens to be with wheel hub off, only pictures I found on file this morning. Circled in red is metal shield of FDS seal.
After driving: Remove grease cap, tires on ground: Axle of FDS should be pushed out on it's own, measure gap between hub flange and snap ring. If on jack stands, a jack under LCA, helps extend outer axle of FDS outward. BTW: reusing grease cap is not a good idea. If seal of grease cap to hub flange is not water tight, water gets into bearings grease, during water crossings.
After wheel bearing service. Wherein, axle bearing and bushing has also been lubed:
Tool(s) for pulling axle to settle grease, can be made with stuff lying around the shop.
