lol....so if you need wood up north you just pull a few treated laths from the neighbors wood fence to do your Bbq'ing?
According to beaufort.
He's apparently an expert at Yankee wood lore and reading comprehension.
ribs.... they have about as much meat on them as chickens feet.
that's because you use s***ty meat...
wait a minute, who said it was ok to par-boil ribs?
a yankee on wet wood...
"We have found through extensive testing See The Winning Edge that the moisture level is key to the smoking results and we believe the consumer should know!"
Wood Chips - Smoking Wood - Moisture - Barbecue Wood Chunks
Wood Chips - Smoking Wood - Moist Table - Barbecue Wood Chunks
There are more differences between green and seasoned wood than moisture content.
what are you cooking? roadkill?
yooper, if your smoking meat then beaufort is right using green(high moisture) wood... if you are grilling/regular Bbq then seasoned (dry) wood for minimal amount of smoke and maximun amount of heat...again results may vary according to region...lol
name a few... I'm just saying firewood and BBQ wood are not the same thing. So why would burning wood soaked in tap water be better?.... is chlorine and fluoride healthier when it's smoke form?
