My smog pump was starting to squeal more and more, so I decided to replace it with a reman.
Got one from NAPA and...don't do that. Pulley would not fit (unless I flipped the pulley around, but this pushed the belt too far), would not fit in the mounting bracket, and the hose fittings off the back are not exactly stock set up.
I am supposed to get one from O'reilley's tomorrow, part number 33-768. I am hoping that one is a better fit.
Meanwhile I decided to open up my squeally Nippendenso. Looks fairly simple. I located replacement bearings using part numbers I found in another smog pumpthread. The vanes look good.
Some questions:
1) Where are the carbon wipers supposed to be?
2) Is there supposed to be an air hole near the center back plate (see pic)?
3) Does this pulley mount press off?
3) Anybody have luck with the O-Reilley's brand pump?
4) Is the 33-768 a Cali spec. or fed spec?
and some pics:
Some questions:
and some pics:
