Smelling gas
Broski
I love Wheelin my 80
At the edge of the Pacific ocean
After a hour or so on the trail I smell gas. It gets bad but I cant find the source. I first noticed it at Cruise Moab out on the trail. By the next morning the smell would be gone, On the road part of the drive to trail & the first hour or two it would be fine then it would start again. Bad enough that My Wife would get out and walk the trail. Had Shoppy here on Mud do a smoke test on the gas tank at his Shop but found no leaks. Was wondering if you guy that had a leak in the gas tank smell gas all the time ? or can you see gas leaking. Any help would be appreciated.
When my charcoal canister let go i had a pretty horrendous smell of gas. It was always coming from the front drivers side and i could smell it in the cab with the window open. Do you get a hissing sound when you removed the gas cap?
No smell at the canister/ no pressure at the gas tank.
What does a pressurized gas tank indicate?
That your tank is sealing properly! It should eventually bleed out thru the carbon canister, but holding pressure, to a point, is a good thing.
Have you ever changed the charcoal in the canister or changed the canister for one of the generic offerings?
My 89 Toyota truck & 85 FJ60 have pressure in the tank. No gas smell from the truck. After the 60 has been sitting I can smell gas in the engine bay - assumed that was gas evaporating out of the carb....?
Oops, thought I was in the 60 section. This advice probably doesn't apply.
Check to see if the smell is coming from the distributor vent which pulls fresh cabin air through the distributor. The filter is located on the passenger side, fire wall partially obscured by the blower motor. You'll need to pull back the carpet a little to see it.
Another possibility is the fuel filler tube leaking into the right rear quarter panel. Fix for it is a new gas cap. This is unlikely if you passed a smoke test.
My 3FE did the same thing about 8 years ago. It turned out to be a bad injector. The fuel always evaporates before you can see any liquid fuel.
Thanks for all the replies
My 3fe has been throwing out some pretty strong fuel smell when I turn on the vents, especially when pulling from outside air to defrost the windshield.
How were you able to find out about the smell coming from a bad injector...?
Ruling out the easy stuff first. Sticking my nose all over the engine while it was running. Then when I figured it may be an injector, I did an inspection by starting it first thing in the morning, while cold. Then I could see some fuel under the intake manifold. Once you think it's an injector, it doesn't matter which one, you have to replace or rebuild them all.
