okay been driving my rig for about a month with the rear swaybar connected and the front disconnected and yes it's good for wheeling lotsa flex, but terrible on cross wind traffic if you know what I mean (leaves the front very light especially with fox 2.0's).
I just reattached the stock front sway bar and I automatical can tell how much stiffer the front end is. Good for road yes, but bad for rocks/crawling yes.
So after I thought about it, the swaybar could act like a progressive spring. OME are stiffer than stock by 20% and the sway bar is obviously stiffer than the spring at 28mm vs 18 OME (or something like that).
My question is.....
There a swaybar that I can use in the front that is made for the fzj80 or something that is similar too that can be modified in some way that is thinner in diameter than the stock swaybar?
I know that you can disconnect it but I feel that the front was too loose especially in the sand for a disconnect and will be just happy if there were a stock replacement thinner swaybar.
My question is.....
