small transfer case leak, drip
I spent a few days out on a trail. Drove in 4 low for basicly two days straight on hot days. At the end I saw a drip of oil at the rear of the tranfercase where the rear drive shaft exits. Just one drip and a little wet area cover with dust. I will check the level and see if I lost any real volume. But I think it was just a few drops. Is this a common thing after running low range for extended time? Should I consider a transfer rebuild in the future?
I am thinking of doing u joints in the next 6 months or so. I would imagine the t case is easier to get out if I already have the drive shafts out. I don't really want another project like this but if I pull it, it will get marlin gears as well.
A rebuild, no. Rear seal replacement, sure....If you are sure it's leaking from there. Could be speedo O-ring.
You don't have to pull the whole case. Just the back half.
As someone who just rebuilt a tcase, I would never again rebuild a tcase as pm. I know it's all the talk these days....
If doing crawler gears, I would definitely take and extra 90 mins in the front end and drop the entire case and do it on the bench. I've never installed the gears under the truck, nor could I imagine doing so. Ymmv.
I have helped do about half a dozen sets of Marlin gears. All IN the truck. Not that hard. Most of the metal removal is done to the rear portion of the case that comes off. Biggest challenge is replacing the gear cluster into the case after assembly. It really takes 4 hands, so best done by 2 mechanics that are used to working together. Takes just about a minute, if you really have your sh*t together.
