SM 420 shizz
Cottonwood, Az.
Well, I've had my SM 420/ 3spd. case in for almost 2 months now, and really love it. There is a bit of a downfall with the on street driveability, but the trailability far outweights any drawbacks. Compared to the stock 28:1, the 67:1 makes you feel like you can do almost anything. And for alot of trail puttin', you don't even need to shift into low range.
Buuuutttt.... when doing the install, I was kind of in a hurry and didn't do some of the things I should have. Like not going ahead and replacing the tranny synchros. I was trying to find an earlier thread where someone mentioned greasing the bearing in the adapter, and putting some washer between that bearing and the t-case. I didn't grease that bearing, and didn't put in any washer. I also kind of knocked in the t-case input gear when assembling the tranny and t-case.
Why this is a concern? I dropped the oil in the tranny about a week ago before my trip to Martinez Canyon, and found alot of metal in the bottom of the tranny. Wide, thin flakes, and some small, millimeter sized chunks. I used a magnet to get out as much as I could, filled it up, went on my near week long adventure, came back, dropped the oil again and found more metal. I went to drop the t-case oil, but pulled the fill plug before doing so, and had oil gushing out. So the t-case input seal is bad at the very least. The tranny grinds a bit every so often shifting into 3rd, so since I have to at least pull it apart to investigate, I'm gonna go ahead and r&r the synchro and rings.
What I am wondering is a couple of things. First, what kind of grease to use on that adapter plate bearing? Second what's the best way to assemble the t-case to the tranny so that you don't screw up the seal?
Really, I don't know where the metal is coming from, only after a dissassembly will I know for sure, but the adapter bearing seems the most likely candidate.
Rush, Please keep us posted on updates. I finished my install last week and wasn't able to replace my synchro either (3rd gear is go bad) and I had not heard about greasing the adapter plate bearing. My adapter came used with the bearing installed and no signs of grease on it at all so I didn't mess with it. I'm trailing testing mine next weekend and was planning on draining it then to check everything.
I've also noticed an asbestos type odor. Is this the clutch wearing in or about to give out?
PIN_HEAD, any ideas / suggestions?
it is not the third gear synchro going bad , it is the bearings that ride between the input and output shaft , the 420 will work even when it is howling so just run it till it gives up the ghost.
RUSH55 said:
Not sure as to what you're refering, pees. Are you talking about the needle bearings? If so, why do you say that the prob as far as grinding into 3rd? I would rather pull my tranny now to see whats going on before any real damage occurs.
66, did you get your 420 in already?
It's in, just picked up my front driveshaft today. I still need to build a shifter boot and try to get the clutch odor figured out. According to my GPS 1st gear Lo at 2500 rpm's is 2.6 mph. Going out next weekend to wheel it before we go to the Roundup.
Roundup, MT?
What's happening there? I have kin in the area.
Kirk
Why this is a concern? .
I always recommend at least replacing the 3-4 synchro rings. They are cheap and easy to do. Most people inadvertently disassemble their tranny anyway as the mainshaft tends to fall out the back.
You don't need to grease the bearing. If it is a sealed type, just cut away the seal on the tranny side.
You do need the washer. Without it the gears in the transfer won't mesh properly.
66fj40x2 said:
I finished my install last week and wasn't able to replace my synchro either (3rd gear is go bad) .
Replace the synchro rings. I wouldguess that the smell is just hte clutch wearing in.
