slight tire size dif= diff probs?
Bellbrook, OH
hi all,
cheapo that i am, rather than paying $800 for a new set, i'm systematically buying used ltx's in oem sizes for the '97. one came in and was a S rated, instead of H, and is 'slightly' smaller, meaning maybe 1/2" diameter. after installing on the left front, the truck ever so slightly pulls to the left when starting from a stop. no biggie... but wondering if this slight size difference will cause the diff. to work overtime, heat up, etc. and reduce it's life. wouldn't think it wouldn't think it would, as used and new tires have that much size difference and they must have designed enough slippage for it not to matter, but thought i'd check the board...
now have amsoil gear lube in it. thoughts?
thanks.
u checking the mfg dates on these tires?
lol...
i'm uniquely cheap, so shoot me!
yes, yes, i know mixing tires, etc...
no, not checking dates.... i know rubber, silicates age, etc...
I wouldn't do it, but I'm not sure what damage might be done. I suppose as long as the center diff VC isn't locking up, it's probably not doing any damage? Center diff would be my main concern.
We have had 2 members, over the years, that have reported problems with the center diff. One (landtoy80) speculated his problems may have been due to different sized tyres.
The other member bought his vehicle used and was having severe problems with his center diff (actually the VC). As I recall, those problems were directly linked to having different sized front and rear tyres. I cannot remember the size differences but they were marked as different sizes (265 vs 275 or something like that)
Several have speculated that having different sized tyres will adversely wear the VC. Personally, I think minor differences (1/2" or less in diameter) would be OK but that's just my feeling and is not based on any known fact or technical information.
-B-
why would the center diff know anything? the main rotational difference is between the left and right fronts. by the time the front diff works that out, it's a constant speed to the center...? firetruck, you're thinking that that small speed difference b/tw fr and back might do something?
Yes, the center diff VC will lock up with slip, which is basically a difference in speed between the front diff and the rear diff. Depending on where the different sized tires are, it could create a constant difference in speed between front/rear, making it think there is slip, and locking the VC. The front/rear are open diffs, so I have no real concern with them.
OK, while there is a mismatched tire size topic running... I've had a nagging question.
33" GY MTR tires 285/75R16 load range D.
4 on the ground all have 16/32" tread left.
1 on the back (spare) has 19/32" tread left (never run).
I know we're takling 3/32 here... Less than 1/8". The tire guys I had do my balancing were leary about bringing the spare into play on an AWD vehicle with more than 1/32" difference. I thought it sounded a bit silly.
So, given my super-even wear so far (I'm thrilled btw.) there isn't a high wear position to drop it into that I can detect.
Am I too late to rotate the spare in? If I bring the spare into play, which position should I put this now 'odd' sized tire in to minimize complications?
Thanks!
My anal retentive side comes into play here.
Are you gioing to screw up the diffs by running a 1/2" difference in tire size?? probably not.
are you going to over usethe center diff and cause a thermal ??? possible to likely.
Is your vehicle going to drive like s*** and stop funny and generally be scary to drive if for some reason someone else got behind the wheel, and wrecked.
Dave
Haven't worked it out completely in my head, but I'm pretty sure it would. With a smaller tire on left front and the other three the same, then (assuming straight, level travel, etc.):
Front right axle, both rear axles, and rear driveshaft all rotate at the same (slowest) rate. Left front axle rotates the fastest, front driveshaft rotates somewhere in the middle. This is also falsely assuming no gear reduction(?) in the diff's, but that shouldn't be relevant.
Curtis
The propellor speed (in rpms) is the average of the two wheels' speed (in rpms) multiplied by the rear end gear ratio.
When driving in a straight line, if one of the four tires is a different size than the other three, then the center diff will have to differentiate. I saw a chart somewhere regarding the silicone viscous coupling action versus differentation. I recall the center diff does allow a slight amount of differentation before viscous coupling ramps up, i.e. the larger the differentation, the more the vc forces coupling (resulting in friction and heat build up).
Thanks!
Well, I can't say one way or another if your 3/32 makes a difference or not, but if you are sufficiently concerned, you can take the spare to a tire shop that caters to the local racing crowd and have them shave down the tread to be same depth as the other tires.
thanks for the info, all-- it's clear that i have some measuring and calculating to do before we can find if the amount of slippage we're talking will engage the VC in the center diff....
per tire rack, the new ltx's in S and H rating are the same size! but my almost new 'S' is clearly, though slightly, smaller than my new 'H'--- so, i have to measure.
however, IF-- the left front 'S' is say, 30.8" diam. vs. the 31.3" for the 'H', that is 1.6% smaller. IF we then assume the front diff equalizes between the 2, the diff. front to back would be half- .8%- right?
comparing a pure diameter/speed/tire size---
at 666 revs per mile, (per tire rack), .8% is 5.3 revs per mile- or per minute at 60 mph. this equates to an extra rev. every 11 seconds at 60 mph.... hmmmmmm more than i had guessed.... this seems a lot?
BUT, do i need to factor in the final drive, which should mean the drive shaft are turning, what 4 times, for every wheel revolution? however, the percentage difference b/tw front/rear stays the same.... arghhh.
so driveshafts are turning maybe 666/4= 166 revs per mile. .8% of that is 1.33 revs difference every mile, or minute at 60. that sounds negligible...
i will measure and get back... thanks.
you need to be concerned about the circumference not the height of the individual tires. any difference in height will be greater (on a % basis) when you compare the circumferences.
[beating an almost dead horse] you really should check the sidewalls for mfg dates. if any of them are four digits, you have tires that are at the very least six and a half eyars old.
$0.02
circumference is a product of pi and diameter/radius, so differences in diameters or circumferences by percentage are the same. thanks....
will look at mfr dates.
ok, so i measured the tires-- the 'H' rated is 30.5" diam = 95.77" circum.
the 'S' rated is 30.125"= 94.59" circum.
So, if we average the two at 95.18" circum (which is what the front diff will do) and compare to the 2 'H' rated in back at 95.77", we have .59" diff, or .6% rotational speed difference b/tw front and back.
95.77" circum is about 662 revs per mile.
and here's where i need help.... how fast are the driveshafts turning compared to tires?
IF they turn same speed, then in my case, the front will turn 4 turns more per mile than the back, due to the smaller tire (.6% of 662).... before i ask if that's harmful, need to figure driveshaft relative speed.... thanks.
You are thinking too hard about this. Just ask Eric what he thinks (via PM) and go with his analysis.
Stock diff gear ratio is 4.10:1 front & rear.
Driveshaft speed varies depending on transmission gear.
O/D is 0.9:1 (IIRC)
-B-
Due to financial concerns, I was also thinking about finding used tires just to get by...
Would a mixture of 265/75/R16 and 275/70/R16 tires be ok if I removed the drive-shaft and locked the center diff with the fuse pulling method ?
By removing the front drive-shaft, I can theoretically use any tires I want in the front, right ?
And the rear axle... I could just match the tires as best as I could ?
Thanks for your input !!!
97 LX450
stock and unlocked
