Slider Build
CO MTNS
Started this project back in February and am mounting these up this weekend. I did lift the truck, do some other pm and build 2/3's of a front bumper in the process. Not to mention learn how to weld and work metal. I have always been proficient with wood, but metal work was new to me. Hence some of the cobby welds. I always had good penetration though. Oh, a tip for you other wood workers. DO NOT use your $700 sliding compound miter saw to cut 1/2" steel plate or bar or any other metal for that matter. I spent 3 evenings rebuilding and cleaning my saw after this. Learned how to get real good with a grinder and 14" HD chop saw after that. Whish I had a oxy torch.
A big point. If I had a thousand dollars. I would just go buy these from Slee or Metal Tech. I spent upwards of 30hrs working on these, testing, measuring, cutting, fitting, freezing in my garage at 3:00am, and am not 100% satisfied with the end product. I have a tucked up aftermarket exhaust and the PS slider still doesn't work out real well with the exhaust. I ended up needing to weld the PS side on aside from my cat plate. Which I think turned out awsome and wasn't really that hard. Just cut and grind to fit. I found measuring wasn't really as effective with this project as test fitting, clamping and grinding.
Some Details:
I used 3/8" plate for the body mounts and cat protection plate and 1x3x1/8" for the sliders, out riggers, and most gussets. I am not a big believer in heavy crap on my truck so I tried to keep these as well as the bumpers I am working on light. I would say they are about 35lbs ea. I can curl them with one hand? The DS in particular is stout. this thing isn't going any where. The tube may dent, but it will not do any damage to the body. All this 3/16 and 1/4 stuff is just too heavy. DS is ubolted on with some custom u bolts ($60) for 6 of them. PS is welded and bolted at the cat plate.
I used a laser plumb level to get the out riggers just right. See pics. I cut them real close and then put the laser on all 3 mounted to the body to get a straight line to weld the main slider too. Used the grinder to get them just right on the laser line, then clamped the slider body on and tacked in place. These parts were easy. It was all of the little gussets an testing and fitting and grinding that takes tons of time. All in all I got a beefy slider for what would cost most people about 200-220 in metal, grinder disks, chop saw blades, welding wire and bolts.
I still need to get some tube bent up for the outriggers and welded on but that is acctually going to cost $ so I am going to wait a bit.
Some pics below. If anyone has questions, let me know happy to share knowledge.
Please no comments on the cobby welds. These things will hold and I got pretty good at laying a bead by the end.
All that said. There is huge satisfaction in teaching your self a skill and building a complex part like this. I highly recomend it to those contemplating buying or building.
Tacking in place
http://i900.photobucket.com/albums/ac202/kmcoop7/Slider Build/DSC02935.jpg
Using the laser to get things lined up.
cat plate
DS Slider
PS Slider
high clearance
Thanks, for the welding complements.
I forgot to mention high clearance was the goal here. That is why I selected the 1x3 instead of 2x2 or 4. Using the 2x2 or 2x4 just gets you back to where you were with running boards. I am only about 1.75" below the pinch weld to the bottom of these.
My jack isn't tall enough to pick the truck up with these on, but I don't think they are moving at all. No flex at the ends, particularly on the DS slider with those big gussets I put in.
kc
holy cross
As soon as the snow melts I'll head up to Holy Cross and abuse them to see how they hold up. Probably a month from now before you can get up there though.
very nice - looks strong and well thought out :cheers:
