slee rear control arms
Hi,
I am going to be ordering the slee 4" lift. wow is it pricey. do i really need the adjustable rear control arms? what will the problem be if i do not get them?
thanks....
Hi,
thanks....
Yes. If you have rear driveshaft vibrations, you can correct the rear pinion with the rear adjustables by measuring the angles at the tcase and the diff and adjusting accordingly.
Worth having with anything over stock in my honest opinion.
Best.
-o-
I have his 4" springs and don't have adjustable arms. I'd wait and see how the truck runs before ordering them.
Same here.
With the 4 inch lift, you will have to do something about the panhard rods. I used Slee's. No problems at all.
On my OME 850/863 lift I don't need these for driveline vibrations. However, I was toying with the idea in order to move the rear drive shaft up a bit for clearance. Do they have enough adjustment in the other direction to do this? My thought was to move it up until it vibrates then bring it back a bit.
Good idea? Bad idea?
-Spike- just recently did something like that. Search out his recent threads.
Also talk with "Taz" on this one. He can give you some info that may help.
Didn't mean to give the impression that there would be a problem with Slee's rear adjustable panhard, it's just that I think MAF's bracket is a better solution.
It's always better to have the panhards at level as possible. Does anyone feel differently?
Agree, and mounted as high as possible. If possible it's better to raise the axle end, than lower the frame side.
it appears thats what most Jeep kits do. They have brackets for those cute little axles that raise the mount. The rear looks pretty easy to do that.
Anyone know the OD of the front panhard??? :confused:
<<<EDIT>>>
any reason you can't tap the front solid rod and add an adjuster? use jam nuts to keep it tight? Or could you sleeve it with dom(provided you had some for free ;) ) and add the inserts used for the rear like brodis did?
yes I know it would be easier to just spend the $100 and do it, just wondering if it's possible to do it those other ways?
You should not raise or lower the front as that will pull it off the plane of the draglink, and you'll get bumpsteer. You'd need a drop pitman arm to go with the panhard, and the 80's pitman arm is already low and exposed to the front of the vehicle, so that's not a good idea IMO.
80's are wide and have a long rear panhard, so you don't get much angle and certainly no rear steer that I have felt on 3.5". One of the big reasons to replace the panhards is you have old rubber bushings that may allow slop in the handling. I went to Slee's new rear panhard with poly bushings and the handling is noticeably tighter. I need to do the same up front and just carry a set of spare bushings. But no reason to get complicated here - a simple set of adjustable panhards is all you need.
Nay
