slave cylinder push rod
Bozeman, MT
The clutch in my 55 is still slipping and Trollhole said he the pushrod from the slave just needs to be a little shorter. I was just wondering can you buy one that is shorter or is this a fab job to shorten it a little and make it work right.
If you are out of adjustment, (as the end of these are threaded and there is a jam nut on them, loosen that, and back the large nut down a bit) you could easily take the rod out of the slave cylinder, and shorten the end that is rounded and seats into the slave cylinder piston.....
Good luck!
-Steve
the adjusting nut was all the way back. I'm thinking he will need to shorten the other end. Man it was good to get it running after a year! ANd running good at that.
