I have the Slee transfer case skid, used it this weekend up in CO
For where though? What are you guys using skid plates for?
Most all production skids are for the tcase and act as a replacement crossmember as well.
I wouldn't bother anywhere else unless you had a rear accessory in spares location (subtank, air etc) Front skids are a bit more on the mall bling side of things. Gas tank already has a factory skid/cover and you'll probably be into a driveshaft first
I have used and abused my IPOR for many years and wouldn't hesitate to buy one again
Actually. That's a great thought, and one I overlooked.
Even the 8" pipe cap trick is better than nothing. My drain us have become one with their protective raised collars
Do it before you have to R and R those rings .... And switch to hex/Allen head drain plugs too at same time in case they take a light hit
The pipe cap is just a cheap base to form a diff cover out of. Still needs some cutting and grinding to fit. Just a budget option.
Trail gear makes one (also needs massaging to fit) and I've looked and looked but someone here posted up a red one of unknown mfg that looked very nice
The Allen heads just allow you to remove and install plugs if you barely bent a plug protective collar and can't fit a socket around the hex but inside collar.
Sorry was trying to describe stock housing. There is a raised lip around the plug to protect it. I have mashed mine into the plug which prevents its removal untill the grinder comes out.
You can see I had to open up inside of ring so that hex could spin freely
Worked good?
My transfer case is still in one piece. The plate has a long scratch in it. It will take much worse, I bought it used and it had a pretty good gouge in there from the previous owner. It was bad enough it would have for sure gutted the aluminum case. Anything Slee is going to be solid quality.
I have only heard nothing but good things about slee.
Jason at Cruisin Off Road. Yeah he's Canadian but don't hold it against him. The transfer plate is big and beefy and easy to install. Frees up space to mount in the new "crawl space". It's a serious piece of metal.
That's because their products are so well thought out and executed. I can't believe how nice their front bumper is. I have that TC skid and the castor correction plates from them. Customer service is the best, shipping is fast, and the products really speak for themselves.
