I'm guessing I need shocks. I was in the middle of adding my leveling block to get the lean out and this is what I found. It looks like i'm going to have to shell out for some Bilsteins.
WES1977 said:Update on the Leveling block: The leveling block is installed, it came with the center pin. The center pin has to be trimmed. If your going to try this I would suggest new U-joints. Luckly I have some just seating around. I did not take the leaf springs off but just took the U-joints and lifted the axle to have some room. After the install I still have a lean. I probably should drive it to make my observation. Since I know that the stock shackle are the same lenth in the front and back I desided to put my shackle bolts in the holes that match the hight of the back. (front shackle has holes at 3.2" and 3.75") Well I sheard off the shackle bolt so now i'm waiting on parts.![]()
no I replaced my Ubolts. I had them but up front I broke a shakle bolt.HawkDriver said:You mean Ubolts?![]()
nick said:is it me or does it look like your cruiser's sitting in your living room?
Was referring to them as opposed to Ujoints. I'm still confused, did you replace the ujoints or ubolts? Not that it matters ;pWES1977 said:no I replaced my Ubolts. I had them but up front I broke a shakle bolt.
boy my shackles I have to hammer them to move them.
the upside down ubolts aren't just a matter of flipping them upside down...it's a kit or something you have to make because the plate needs someplace to center on...what do you mean by not fully inserting in the hole? what won't fully insert into which hole?WES1977 said:Does anyone have pictures of upside down U-bolts on a non-soa? It doesn't seem like it would be as strong and the shape of the U on the bottom would not allow it to fully insert into the hole. That would probably make were you couldn't thread the nuts.
nuclearlemon said:the upside down ubolts aren't just a matter of flipping them upside down...it's a kit or something you have to make because the plate needs someplace to center on...what do you mean by not fully inserting in the hole? what won't fully insert into which hole?
WES1977 said:I just saw somewhere that it was mentioned. I haven't touced my Ujoints.
HawkDriver said:That was the point, YOU were confusing me talking about your ujoints. (read up)![]()
Oh forget it ;p
So which shocks you go with?
