Shocks???
Chesapeake, VA
Website
theshealys.com
I'm guessing I need shocks. I was in the middle of adding my leveling block to get the lean out and this is what I found. It looks like i'm going to have to shell out for some Bilsteins.
I had the DT-3000's and have run the 8000's in the past...Billi's ain't nearly as cheap, but the ride and control is much nicer :D
ok i'm guessing I don't have stock shackles. My rear measure from center of bolt to center of bolt 3.75" My front has 2 holes. One ate 3.75" and the other 3.2" which is were the bolts are. Does anyone know there size of stock shackles?
Did procomp elcheapo hydraulics for a while, worked fine. OMEs I'm runnin now seem to be a bit better. Prob try the RS9000s or MX6s when it's time to change up, just to experiment with selectability.
I mean what's the big deal with shocks? Do they really make that big of a difference? It's not like we're jumping these things or taking corners real fast. I understand the concept, but I think the expensive ones are overrated. JMO, am I wrong?
Does anyone have pictures of upside down U-bolts on a non-soa? It doesn't seem like it would be as strong and the shape of the U on the bottom would not allow it to fully insert into the hole. That would probably make were you couldn't thread the nuts.
Update on the Leveling block: The leveling block is installed, it came with the center pin. The center pin has to be trimmed. If your going to try this I would suggest new U-bolts. Luckly I have some just seating around. I did not take the leaf springs off but just took the U-joints and lifted the axle to have some room. After the install I still have a lean. I probably should drive it to make my observation. Since I know that the stock shackle are the same lenth in the front and back I desided to put my shackle bolts in the holes that match the hight of the back. (front shackle has holes at 3.2" and 3.75") Well I sheard off the shackle bolt so now i'm waiting on parts. :doh:
WES1977 said:
Update on the Leveling block: The leveling block is installed, it came with the center pin. The center pin has to be trimmed. If your going to try this I would suggest new U-joints. Luckly I have some just seating around. I did not take the leaf springs off but just took the U-joints and lifted the axle to have some room. After the install I still have a lean. I probably should drive it to make my observation. Since I know that the stock shackle are the same lenth in the front and back I desided to put my shackle bolts in the holes that match the hight of the back. (front shackle has holes at 3.2" and 3.75") Well I sheard off the shackle bolt so now i'm waiting on parts. :doh:
You mean Ubolts? ;)
HawkDriver said:
You mean Ubolts? ;)
no I replaced my Ubolts. I had them but up front I broke a shakle bolt.
boy my shackles I have to hammer them to move them.
nick said:
is it me or does it look like your cruiser's sitting in your living room?
That made me laugh.
I bought a model home and the office was the garage. So free carpet and finished walls. :)
Was referring to them as opposed to Ujoints. I'm still confused, did you replace the ujoints or ubolts? Not that it matters ;p
the upside down ubolts aren't just a matter of flipping them upside down...it's a kit or something you have to make because the plate needs someplace to center on...what do you mean by not fully inserting in the hole? what won't fully insert into which hole?
I didn't mess with trying to flip my Ubolts. I just saw somewhere that it was mentioned. I haven't touced my Ujoints. I just added a leveling plate onto my leaf spings.
HawkDriver said:
That was the point, YOU were confusing me talking about your ujoints. (read up) :rolleyes:
Oh forget it ;p
So which shocks you go with?
sorry I found were I put Ujoints and changed the text.
Nuclealemon is right about the flipped u-bolts being a kit. You can't just put yours in upside down, they won't reach or won't stay put or something wrong.. The kits come with, or you fab, another plate for the bottom of the axle and it all uses square u-bolts.
Costs a bunch for the kits at Man-a-fre, I think someone else has another kit that's less money.
It's for no more bent or messed up threads on the u-bolts.
