ATS,
What bilsteins would you run on a LC with a 2.5-3.0" lift?
Does Christo have the same set up you guys run down thier?
Christo has (at least he had them at one time) the longer Bilsteins you need for the 100 with 2.5-3" lift.
ATS,
I can't get a photo, but the lower rubber bushing (underside of shock tower) is sandwiched between the two washers with the curved lip of the washer on top with the curve up, potruding into the hole in the shock tower and the non-curved washer on the bottom. The washers that go on top of the shock tower don't give you a choice as one has a smaller hole that will only fit over the very top of the shock bolt. Hope this is clear. It is pretty evident when you see it and think it through, however, I screwed it up the 1st time.
He is talking to you too since deep down you still dissatisfied with your JUNK OME. OME are no good for IFS. The only OME that I really satisfied with is the one on my old Samurai.
Fish:
Hope you resolved your shock issue. I ended up swicth back to original shocks and the thunking is gone. The shocks may be a bit softer not much.
I have the 2 front billies if anyone wants to try them on their truck
