Build Shipwreck
these things.... no joy
so this.... was tonight's work
a bit of splitting
and fitting
and tacking
and more fitting
and lots more work to do.... I need to cut the top of that rail off the bit I built
onward
a bit of trimming
and a repair - if anyone wondered why I decided not to powder coat now.... here's ample reason
push it down
drill and weld
and some door stops
hmmm, it seems not all pulleys are created equal... dagnabit!
no picture of painted, but that's drying so that I can finish the front half of the top tomorrow.... and wait for the new pulley which won't be here until Friday
they aren't different.
remember the inner panel is the same on all 4 doors. I'm putting handles on the 1/2 doors but they're decorative only to open you have to reach inside
finally back together... normally Sat. night I don't do anything - but I need to get this so it runs so I can test the module
correct pulley
and new belt - one that's between the too long and too short (1005 rather then the 1010 that was on it first and the 1000 that was too short)... yeah, 1/2"
everything works great. spending the day getting jiggy with dry rot on the house....
drove it today - runs excellent.... I utterly hate it when I follow instructions, despite my better judgment, and they turn out to be wrong. All the books say set the timing at zero degrees with the distributor disconnected. The author must be a Ford owner, because, just like Fords, he's all wet. 6-8* is good, 10* is better. .... and it doesn't run as warm - 180* vs. 220*
*sigh* and my wife wonders why I don't do instructions
in other news, I hate wood.
Noisemakers
and time to eliminate the land cruiser lean
take apart
template
this rubber is theoretically supposed to be for landscaping - it's made of recycled rubber... also works great as a shim
and I had to recharge the front shock again... I think it's going to need to be sent back and get looked at by the pros.... all the rest don't leak at all
Not that I've ever actually tried this before but the rubber mats they use for gym floors also work really well as shims...
weekly update. I've been building a deck and repairing dry rot so things have slowed down on this... fortunately, I'm at the point where I simply do a few minor things and drive it a lot
half doors continue
frankendoors
