Shifting Windshield???
Indiana
Ive been having this issue since I bought my truck. When I am going through bumpy areas or hitting chuck holes on the way to the mall there is a squeaking noise. I am almost certain its the windshield shifting around in its hole. There are no signs of any leaks whatsoever. Has anyone ever experienced this? I might be losing my mind. The only other possibility is maybe the dash is moving around.
My windshield did the same thing. It was installed without sealant. It was also a aftermarket gasket. I had it removed and re-installed in a OEM toyota gasket along with sealant as per fsm. No leaks or squeaking after that.
Thanks for sharing. Do you recall what it cost you?
R&R was like 200 plus oem gasket.
Geez! I could buy some cool purple under chassis lights for that!! To bat, my rear sliders are leaking, kind of badly. May tackle that on my own. Windshield? Nope. I am going to see if I can lift the edge up enough to put a small bead of Dymonic in there....
Good luck. If you use the appropriate sealant as called for it is a sticky mess. I would prefer a front end rebuild over the disaster my garage was with that sticky black stuff everywhere. Lol
Yep. I was just out in the garage thinking of a plan to do it. I'm capable with caulk but getting it in there will be a challenge. If I use a plastic shim and lift the lip up and as I slide it along follow it with the caulk gun. Dam snorkel.... I have a few tubes of the Dymonic caulk and it is nasty stuff but it lasts forever. Pretty sure I know how they are disposing of nuclear waste....
