Shift lever knob
musthave
All maps, one app!
Supporting Vendor
Florida / Colorado
Purchased a new shift lever knob. Having issues removing the OD switch.
I found this thread but it shows a different type of connector than what I have.
Removing the leather shifter handle for replacement.
I can separate the connector as shown in the below photos but I'm not sure how to take the wires off this flex connector and be able to reuse it. Suggestions?
I deal with similar issues as a model railroader. Odd little connections that getting the parts to is near impossible. I can see it's a crimped connection, but may be soldered, too? Try some needlenose pliers to peel back the tabs that are bent over. They look like copper, so should be easy to bend, but just enough to get the wires loose. If they are soldered underneath, apply a clean soldering iron to some desoldering braid to get them loose.
If nothing else, you could cut it off and simply solder new leads to it.
I think that end isn't meant to be disassembled. The connection under the console gets fished up the shifter stalk IIRC
Agree, the wires get pinned out of the connector and the wires are fished through the shifter.
Somehow I will separate them from the connector. They didn't make it easy. In removing it I have a spare retainer clip made of metal. Unfortunately I do not see where it could possibly go. However I do notice that the overdrive switch no longer act like a switch. It pushes in and out but does not click.
