She's Mine!
Did you end up buying springs? What tires did you get? I would let the steering be the judge on whether you should replace the tie rods or not. If it doesn't wander around much, then I would just clean them up a bit and let them be.
Hey Raddic,
I have the OME suspension and I'm getting the BFG MT's. Seems to be a winning combo. I think I will leave the tie rods alone for now...steering felt fine, so I'll just gently clean off the crud. Think I'm going to hit the frame with some rust inhibitor and chassis black while I have everything off.
Hey Raddic,
Nice choices. I'm excited to see how it turns out. Now stay focused. ;) I wish I was a little closer. I would love to come help.
yep. got the rims back last week...bought the tires. Rig is up on Jack stands right now...I'm priming and painting the frame, treating all the rust underneath. I had to order more paint...supposed to be here by friday or so. Didn't realize how much scale and surface rust was on the frame until I got the tires, spring and shocks out of the way. Going to try to do the best job on the frame whie i have it taken apart like this.....think I have about two years before I'll have to pull it apart completely for a re-spray....too many areas are too rough...I'll have surface rust turning to cancer before I know it. My plan is to have it all back together again by the 3rd of march (painting's making it take much longer)....taking a bunch of pictures...I'll post when I'm done...didn't want to post again until I completed this part. Any tricks you picked up that'd make installing the new springs easier? old ones came off super easy (front at least...haven't pulled the rear ones yet). Also, if you get a chance you should have a message from me on front bumper...need to buy a new one.
Thanks,
Kevin
Scale... Its the results of a vehicle being used in a global environment for years. You can be a perfectionist or just drive it. I'm trying to learn the balance too with a FJ40 in running driving condition and the OCD of wanting it to be intimately perfect. Thankfully it doesn't belong to me so I don't seethe over it too much. Enjoying your updates!
Thanks,
Kevin
Nice, a little scuffing and knocking of the surface rust on the frame with a new coat of paint will go a decent ways in keeping things nice for a while longer.
On your tie rod ends, they just look greasy to me. I would clean them carefully like you said and see if the boots are ripped. If they are I think you can replace just the boots or go for all new tie rod ends.
On your front knuckles, I would just power wash those for now and watch for any leaks. Pull the plug off the top of the knuckle and see if there's a decent amount of grease in there. I put a couple pumps in every oil change.
If you have oil seepage on your clutch inspection cover, it's pretty easy to pop that off and try to find out where it is coming from. Could be the cam plug on the back of the engine or could be a rear main seal.
Getting old springs/bushings off can be a chore, so if you had good luck with the front end hopefully the rear end will go easy too.
:wrench:
waiting for paint....thought I'd get some other crap done
Ok, stuck waiting for paint, so thought I'd do some other minor stuff. One was taking out the old battery tray and getting a new one....ton of rust and corrosion here. three of the four bolts are really seized up. I've been hitting it with PB blaster on a daily basis....but think it looks like the bracket that holds the tray on there is just connected to the frame on two places (don't want to be crawling it around too much until the tires are back on. is this the case? Think it might be much easier to try to free these rusted bolts if I just took the whole thing out. Here's a shot of the corroded tray
also, thought this was neat.....my build tag was so covered in grime you couldn't even tell it was there.....cleaned it off....that grime looks like it protected this thing perfectly the past 35 years.
Thanks,
Kevin
Looks like you're coming along. On the paint, do what feels right for you. You live in a very wet part of the states so if it has a little rust on it, in time there will be more. I have what sounds like a similar issue but enjoy my daily driver too much to take the time to address it right now. I do think about it on those wet days or following the chemical ice melt truck. On the spring install, just take your time and give yourself some space. I used jack stands on the frame and a floor jack on the axle and then lowered it down to two more jack stands. All pretty simple other then a stuck bolt here and there.
For your bumper question, I went with the HFS shackled bumper. At first I thought it was too narrow but soon liked the look. I think it compliments the ruggedness of the 8274 winch.
PM me if you want to swap emails or numbers. Still hope you come over this way this summer. :beer:
ok progress made...and some questions
ok, so I finally have the front end back together....now I'm stuck waiting for ARB to send a replacement for the pin kit....2 out of the 4 pin kits wouldn't thread into the bracket. Been a ton of different things that have kept getting in the way....promise next pictures after this will be her put all back together.
While I have the back end apart I'm going to finish up the painting of the rear axle and any spots underneath the body that have some rust. I think I should have it back driving by next week. Ok, here are my questions
1. For the front rotor - do i need to do anything to it....decent amount of rust on it...same goes for the bolts for the tires.
2. the rear passenger side had a pretty large shim in there....will I most likely need to put that back in? Hoping to only have to do this once
3. when I paint the axle can I put the rust encapsulator on the drums?
4. Hopefully my bumper will be delivered tomorrow....anyone have a picture of the bumper mount plate...can't recall the bolts used to attach this (Einstein didn't keep them separated and tagged
5. For the rear end anyone have a picture, or point out where the ground should be. Before I took it apart the directional and reverse lights were working...but the tail lights didn't work...hoping it was just the ground.
...also, thought this was neat.....my build tag was so covered in grime you couldn't even tell it was there.....cleaned it off....that grime looks like it protected this thing perfectly the past 35 years.
Where did you find that? I have a '77 and I have not been able to find that tag. Think I might have some different fenders going on...:hhmm:
It's on the inside passenger fender....right behind the battery.
The shim was probably put in there to lower the passenger side to level out the typical driver side lean. That thing is pretty fricken thick though. If it was in there to change pinion angle I would think it was on both side.
The rotor looks fine. They may be warped if you get some shimmy while braking. Hopefully they have enough to turn them if needed. Double check pads. Throw in a set if they look warn they are cheap.
I dont think it would be a problem to paint the drums. Just don't get it on the inside braking surface.
On the question about the tail lights, I had a similar problem when I did the rear leaf springs. The vibration from the impact wrench killed the elements to the light bulbs. Sorry to state the obvious here, but make sure you check the bulbs before chasing the ground issue.
OME install is done
Ok, so I got the following done
1. Rims blasted and power coated
2. BFG 33 MT's
3. Sanded, primed (with rust encapsulator) and then painted with eastwood chassis black....love both products btw, couldn't be happier with how much better the frame looks
4. Installed the new 4+ bumper from Lcwizard....great quality, price and customer service
5. The big one...OME installed! Aside for the trouble I had with getting the springs into the fixed hangers the install was surprisingly easy...I lucked out with none of the bolts being seized up on the original suspension. Front is now 4.5" lifted and rear is 5.75". Measured from the ground to each wheel well...absolutely no cruiser lean....was really concerned that would happen.
Here's the battery bracket and bumper stops. Had to take the entire thing out as the original tray was all seized up....decided while it was out to paint that as well....really happy how this came out....really clean looking
Love how this looks as well...new bumperettes, bumper cleaned up...axle is cleaned up with a fresh coat of paint...no more rust.
Not all went as planned. I liked the rims so much I wasn't sure if I was going to put the hub caps back on....so I decided to get the chrome lug nuts from Cruiser corps....very bad idea. The nuts weren't going on easily, but i kept checking and the threads looked fine....until I got to the last tire....totally stripped this one. I'll be buying some new OEM nuts (the yellow zinc) and taking the chrome lug nuts off....thought they'd protect the threads better...turned out the opposite...now I get to replace a lug...yippie
