She's Mine!
I only have had my HFS bumpers for 3-4 months but have had no problems at all with the finish.
Also, have you thought of a name yet?
Sent from my iPhone using IH8MUD
Sadly, still no name...it'll come to me though I'm sure. I really do like the look of the HFS too. Just have to decided.
That's great! Names are hard to come up with. I named mine ol blue. When i was dating my husband (who passed away) he was driving an blue work truck he called ol blue. He loved that truck. So my kids said we should call the 40 that since its the same color. It just fit! That's his name! I have the "silver bullet" fjc and "ol blue" fj40.
Love the story of where you and your kids came up with the name (sorry for your loss). Think its completely awesome when you see a member of the fairer sex into stuff like this, your kids have one cool mama!
brake light
what was the mounting bracket used? the one that the PO had was definitely not stock since it was on the bracket for the internal controls...don't know what my chances would be for finding a replacement.
Bad cell phone pic (in the rain) of my light mounting bracket. It is bolted to the dash with a sheet metal bracket that the bolts in the back of the indicator light go into. Mounts about 3/4" under the dash. I can investigate more if necessary.
What is this stuff?
Anyone know what this stuff is stuck to the floor? I pulled up the mat to change the shift boots since they were both torn. I haven't seen it before, don't think it's stock, but no idea where they would have gotten this stuff.
Also, anyone know where I can get a plug for the floor...the passenger side is missing.
One other dumb question - I'm going to clean up the rear bumper this weekend...including painting it up. what do you use to plug up the holes to keep the threads clean.
I'm pretty sure it's stock. Mine has the same stuff. Think it's there to help keep the heat and sound out.
SOR seems to have all those little piece so I would think that they would have that plug too.
BR
In case someone else did not answer - The rear step is OEM stock and your Fasten Seat Belt light is in the correct location. The "stuff" on the floor is there to reduce heat and noise in the vehicle, it's stock, removing it would be bad. :-(
The floor plug is available from Toyota last time I checked or SOR. Painting the rear bumper should not impact your threads. Just as rock beats scissors, steel beats paint! If you like, just screw the bolts in a few turns and cover the heads with some masking tape and spray away!
X2. Overton's on the mark..
Thanks Raddic....ended up getting one already. didn't realize that cruiser corps carries them also.
best course of action?
ok, I'm cleaning up my back bumper (got some new bumperettes, new gaskets for the lights, old ones were completely gone). Took off the old tow hitch and and rear step (will keep the step since it's stock, but not going to put it back on for now...needs to be cleaned up anyway, all bent up). at looking at the lights there's some rust on one of them, should I treat this with something, or just leave as is. Will post some pix this weekend after I get the back put back together.
I cleaned and painted mine with the POR Black rust preventer paint
Rear Lights
I wouldn't worry about that too much. Hit it with some navel jelly or paint it with POR as suggested. These rear lamps are pretty cheap to replace. I offer a very nice Japanese manufactured after market pair of these for $89 - Yours look pretty decent however for being 34 years old.
will get it back together this weekend
Ok, I got two coats of eastwood rust encapsulator and two coats of their chassis black on the bumper. Also cleaned up the lights and hit them with some of the rust encapsulator as well.
Will get the bumpers put back together this weekend and will post some shots of them...very happy with it. Going to look much better.
One question. I had tested the rear lights and the signals work fine, but the lights don't turn on when I turn the headlights on. Do directional and running lights run off a different fuse? Tried doing a search but didn't find much. thanks.
Try your hazard switch a couple of times. It's an interesting circuit. Some times when my signals don't work I cycle the hazard switch and all is fine. Or, like many will chime in; a good ground is your friend. Good luck!
Thanks, I'll try that this weekend...hopefully an easy fix.
Also, have to return the aftermarket reflectors I bought from CCOT. Didn't realize the term "identical" is subjective...looks like I'll be going for the EOM rout here too....was hoping for a cheap out on something.
Next up on the list:
Whats the best way to remove rivets for some home made mud flaps the PO installed?
I seem to have a slow leak.....any suggestions for the best way to locate and fix?
Finally, when do you know you need to do knuckle rebuild vs just a good power washing? :) Hoping for the latter.
Then I'll be ready for the road (until my OME is in, get the wheels powder coated and some new 33 MTs). Need to find a place to spray some fluid film and still need to wax her up. Fun stuff.
Is there a MUD discount? I'm about to pull the pin for some. I bought cheap, middle of the road ones and the sockets are already rusting after a year or so. But I do live in the rust belt.
did you get your cluster lights working? It may just be that the dimmer is turned to the "OFF" position - check your light switch and spin it and see what happens.
Your fasten belts etc. lights are in the correct location for '77. The little bracket screws to the bottom of the dash. In '78 this moved next to the instrument cluster on the right. Make sure you have the correct wires in the correct bulb holes. The fasten belts light should go on for a few seconds when you switch the key on, then go off on its own. The brake light should go on whenever the handbrake is pulled, as long as you're not stepping on the brake pedal.
I really like my 4+ Plus bumper, except I did have some powdercoating issues (going to try and fix this winter). I got the one with the hoop and my only complaint is that you can't hi-lift jack off of the bumper. So I think I'm going to sell it and get one of their other bumpers. I just really like how they bevel and close the ends of the bumper, very classy finishing touch.
There is a plug to the right of the instrument cluster on a '77, but it's not rectangular:
attachment.php
Nice Truck, congrats!
Chasing "slow leaks" is how a lot of rebuilds get started. If that's what you want to do, then plan it and be organised.... For the knuckle rebuild, I would go easy on the power washing since it might force more water in. It's not that bad of a job, you just need more rags. Wouldn't be a bad idea to do if you're keeping the truck long term.
Oh, and get more rags. Good luck!
ps: you need more rags for the knuckle rebuild:cool:
Finally got off my tail
Ok, so first I got off my butt last weekend and installed some T5 HO flourescent lighting in the garage....realized I was never going to get anything done with the lack of lighting...sun sets at 3:30pm up here...and the old lighting was useless. So I got my 40 up on jack stands...took the wheels down to Les Schwab to get them powder coated. will get them back in two weeks. Already have all the nuts off of the old shocks...next this week will be to get the springs changed...hoping it wont be too much of a pain...need to go and get one extra set of jacks for the axels. I must admit PB Blaster is an amazing penetrating oil. i think I'd still be struggling wiht the first nut without that stuff.
so I do have two questions....
1. The tie rods look horrible...do I need to replace these? The rig drove great, but looking at them...man they look horrible.
2. should I do anything to the frame at this point? Doesn't seem to be any rust on this really...(PO hit it with undercoating 35 years ago)....should I leave as is...maybe treat the inside of the frame...do the rails while I have easy access or what.
So disappointed i've slacked like this...but now with the lighting I should be able to get a couple of nights a week out in the garage....that'll make the :princess: happy. :meh:
I'll be excited to have this on some new tires and driving it around again very soon.
