shaving the head
You can use an 80 series 3FE, they were out here in OZ from 90-92 to fuel inject your truck or make it into a 2FE but their is no need if you running LPG most of the time. Fuel injection makes little difference to LPG so don't waste your money on TBI or EFI
Your better off with some head work and a better cam to suit LPG, or even go LPG only, the engine can then be tweaked even more as Mace states LPG has a higher octane.
Also in THe USA LPG is PROPANE and GAS is PETROL this confuses the hell out of the Americans so be clear in what your asking for the right answers.
Best solution bang for bucks power up grade would be pic up a 4500 1FZ-FE off Ebay complete with wiring loom and ECU from a later model 80 series
Many solutions to an age old problem.
Just finished a rework of the head on our 1987 FJ60 with 2F. Shaved it .050 inches. Runs fine on 85.5 octane with no pinging. Timing set at the BB. Jim C. carb rebuild for high altitude, de-smog.
My 0.050 shaved 2F would ping just a bit occasionally. I was close to having the dizzy recurved when I made my one and only mod to the emissions system. I removed the check valve in the spark control system. Its the one mounted right in front of the valve cover on the front of the engine. I put a short length of vac hose in place of the check valve. My reasoning was that is was there to maintain the vacuum advance when the manifold vac dropped. My engine would only ping at wide open throttle so I figured I'd let the advance drop back a bit at wide open throttle. It definitely eliminated the ping and didn't appear to affect driveability at all. I think I even did an emissions test with the valve removed.
reviving my old thread.
found a shop that will test and shave my head for $85 AUD, i thought it was gonna be way more.
when you shave the head say .050 or .088 do you have to recess the valves at all?
i am thinking of replacing all my valves etc anyway just wondering if i should get the machine shop to recess them at the same time as they do the head.
I'm gonna say no.
When you shave the head you are reducing the combustion chamber size. You basically make the squish zone smaller in volume. If you recess the valves you make the combustion area bigger. This would offset the shaving the head.
So 3 folks above have shaved their heads 0.050" without hitting pistons with valves. Sounds like you won't have to recess the valves, but it would be a good idea to "clay" the pistons. You can use Plastigauge instead & you'll get an idea of how close they really come. Clay is kinda hard to read.
You put a strip of Plastigauge across each piston in line with the centers of the valves. Then you install the head with its gasket, adjust the valves (very carefully in order of the next cylinder at TDC) , & turn the engine over a couple of times. Then you pull the head & compare the Plastigauge to the chart to determine the valve to piston clearances.
It's a real PITA but not as big a PITA as a valve-to-piston collision.
P.S. Mace is the head gas-passer here, so heed his advice. You probably want dual-fuel gas/petrol as opposed to EFI.
P.P.S. Think of a throttle body as just the bottom of a carby. No float bowl or jets. Just one or more throttle plates. The jets are downstream with EFI.
There have been folks cut the full .100" off and have had no issues..... one thing to consider when raising compression #s, if the lower end is tired (worn) the increased pressure will only bring out the worst in it....
Lots of room between the valves and the pistions.. Not real worries there.
But, Clay is never a bad idea.
Plastiguage most likely won't be touched..
No reason for TBI if you are running propane. you going dual fuel or???
Not positive on the ignition issues.
But they run dual fuel efi/LPG trucks all the time.
Hey guys, yes i have a stock carb, no i'm not going TBI its far to expensive at the moment i already have duel fuel LPG.
I've decided that im machining 0.050 inches off the head.
I'm gonna save up some more over the next couple of weeks and do the bottom end too i think,
biggest bummer tho is that the engine is still in my rig as i dont have the equipment to remove it.
I'm still learning about everything mechanical and i'm not quite skilled enough for a full rebuild yet
i dont think. give me a couple of weeks and i'l take plenty of photos of the uglyness of my 2F.
depends on the year of the head & block
I have yet to see someone take late model head and a late model block and shave the head .100
if its been done I would love to see that.
Ok pulled the rocker cover and sump today and all the other annoying crap that gets in the way, yeh i know its a weak effort but i been sick.
so now i have a question for you smart people like mace n lowtide;
can i pull the pistons and main bearings out without pulling the motor out of the car? can i just pull em from the sump opening?
since i'm raising compression i figured i had better do the rings etc.
by the way how the hell would you get grass in the sump? cos thats what i found in there a little bit of sludge and grass.
cheers,
glenn
If you are going to do an in-frame build or just freshen up the engine.
Clean the carbon off to piston tops. Mark the pistons and the holes so you know where they go back in. Do not mix them up. This goes the same for you rod caps. Do not mix them up.
The piston and connecting rod will come out the top of the engine. They will be installed from the top of the engine as well.
The grass in you oilpan came from a dope smoker who tried to hide his stash under the oil cap.
The sludge came from using Penzoil motor oil.
cheers,
glenn
Good Guess Danimal lol
Serenity, you really planning on replacing the mains as well???
Basically at this time you are talkinga bout a mild rebuild. While It canbe done in the truck, it is a hell of a lot easier just to pull the motor and be done with it :)
