shaving the head
depends on the year of the head & block
I have yet to see someone take late model head and a late model block and shave the head .100
if its been done I would love to see that.
I've done it a few times. No big deal.
Mark...
mace i cant pull the motor as i dont have anything to lift it out with, theres also alot of LPG crap in the way which i legaly cant touch.
my thinking was that if i am raising compression then i am putting more strain on everything, so while i have things apart i may as well make sure some of the load bearing components (pistons, rings bearings) arent going to fail.
i assume i can take the main bearings out one at a time replacing them as i go
i am also on a very tight budget i only have $900 AUD to do this with, so i'm doing the most important stuff first then if i still have money i'll do more, tho i do have a great parts store, GO AUTOPRO.
hey Mark W can i get your opinion on the idea? anything else you recomend i do with my 900?
thanks for the replies guys, i might get pics up in the next day or so if anyone wants plus do a write up for anyone who wants it.
cheers,
glenn
Yes you can replace the mains. It is a PITA but it is possible with the motor in the truck.
i was thinkin i would pull each main and piston etc one at a time fix/replace it or whatever is needed then put it back iin before moving to the next one, i figure that would decrease the chance of screw ups
i know it will be long and tedious but i have the time and in the end i just want my cruiser to go.
man you guys are awesome i would be so @#$%ed without MUD, im a young un and apart from 2 stroke outboards i've never seen the inside of a motor and this is my first build on my last car.
Do you believe it now that Mark W got involved :lol:
Hallo there D'Animal,
I have been reading your answers to all kinds of question and it seems like you know a thing or two about this stuff.
My Name is Andre de Zeeuw and I live in Indonesia, I am extremely interested in shaving 2F head; Please advice the information you need from me to find-out exactly what year my FJ40 - 2F Engine is the car is from 1978 but I think the Engine is from 1981. Definitely I do not need to worry about fuel efficiencies, etc I only need a lot more power, when I racing I always get second (3x already) out of 40 cars….. I want to be first and beat the fastest TURBO on the Island, ha ha. The good thing is I always beat the other turbo cars with my 2F stock engine…..
When I read the HAYNES book it says the clearance from the Cilinder Head "Exhaust valve seat contact with" is (0.0067inc or 1.7mm) so how much could i take off and where do i measure what is still on there right now.
Also if i would take off some off the head this would not effect the opening of the valves as there is a ajustment screw on the valve rocker so the clearance would be the same?
Hope you could give some information on this subject.
Many thanks,
Andre
You are asking the wrong guy.
When it comes to shaving a head, I take it to the machine shop. Follow Mark W's advice.
The top of the pistons have a different shape depending on the year. The heads have a different casting number as well depending on the shape of the chamber. Both of these will determine how much can be removed from the head.
All right, so sheaving the head does not make my car faster, so what does, how about a race-camshaft? On the moment I have a D.U.I. and a new Japan Carburator, or a 4 / 5 gearbox? would that help?
Making the truck faster would prolly be a different thread. Gearing and tire size will prolly make a bigger difference than compression. Cruisers arent really known for their speed- its more of a tractor. on the other hand, some guys have gotten insane gains out of their rigs. Depending on what your purpose for the truck is, there may be different suggestions to help your situation out. Might try posting a new thread called....faster-or something. HTH
Shaving the head will increase the compression and will make your truck "faster"
How much is relative....
Ok, thanks I have been reading a lot on Ih8MUD and found a exhaust manifold that would help the flow a bit, 3Fe manifold I will try to get and polish the inside of it, then the intake I will polish the inside of it, also the D.U.I. will help, maby my engine is not ready to sheave the head off as it is doing so well in the races on the moment, tires are 35 inch.
