Shackle replacement
What other replacements may be nessessary if i replace all of my fj55 shackles with Sor heavy duty sackles, which will essentially lift the vehicle 1 Inch? Could there be any driveshaft problems? Other than all the possible cutting and torching is it possible to just take out the old and in with the new? I intend on buying new pins and bushings, ect. Thanks fj55 miles unknown
When you say lift 1 inch, do you mean over stock or over their current sagging height? Even with 1 inch over stock there will be no driveshaft probs. And probably won't notice much of a caster change and if you do just put the wedges in. Good luck those pins are a beast to get out.
i only have one thing of advice. spray those old bushing w/ WD40 for like a week and let them soak or you will kill yourself trying to get them out. i did my front ones and it took half a day to get the old ones off. then i helped a freind do his after he soked them and the sliped right out.
All new bushings are a great idea..... also, don't forget the LUBE. Forget the torch, use an air hammer. It is a $25 tool availible at spralmart for your compressor. Hearing protection required...
Ask me how I know, just not in my right ear. btw I've seen a pic of your 55. Its REALLY really nice man!!!!
oh and my friends fj we put shackles that are 4" longer than stock and we had no problems with any driveshafts or anyhing like that. except for the shocks being short but you wont have that problem
Thanks, you guys are quick. Placing an order now, just wanted to make sure i wouldn't have to order more stuff after she's in pieces! 1 More inch + 33x9.5x15 MTs or MT/Rs. Impact wrench should do it, underbody is cherry. But will start lubing just the same.
lube make everythign go down smoothly. haha. oh and if you can afford them get poly bushings
I was going to ask how you calculate your 1 inch of lift - sounds like others have reminded you that 1 inch over shackles won't give 1 inch of lift.
You do need new bushings - greasable shackles and pins are best.
I would urge you to think about lift springs in the future and keeping your shackles shorter, as longer shackles exagerate slop in your front end = more wandering around on the road...
