2003 LX470 220k miles. Just did the timing belt which included water pump, tensioner, and fan pulled bracket. Belt was also replaced. The belt still squeaks when I cold start it. It goes away after a minute or so. Anything I could do or check for before talking to my mechanic?
I hate the cold weather squeaks. I have replaced every single spinning part under the hood and still have occasional noises.. I currently have a timing belt related noise only when cold, hasn't made a peep all summer but once it dips below freezing I will hear it again and get sad...cant justify replacing parts again
To Diagnose your problem :
- Remove accessory belt
- Start engine
- Does noise go away?
> Yes , then start to troubleshoot all accessory pulleys. Start with idler, check tension and smooth operation, it should not free spin like a skateboard wheel.
> No? Then grab some tissues to wipe your tears because the noise is coming from the timing belt / related components. +5 points for replacing fan bracket pulley, I've been seeing more and more post about failing fan brackets
( OR, not as effective in some scenarios but could start with just a squirt of water onto the accessory belt and see if the noise changes, but that's not as true of a test and removing belt )
Around 200k all of these spinning parts are getting old and will start to show signs of wear / make noise
>> Did you do the timing belt because you had a squeak?
