For Sale Section 122-Saginaw Power Steering Pump brackets, So Cal
Lighting fast shipping, and looks to be great quality. Thank you. Working on fitting it up now.
UPDATE: Would a chevy small block type pivot bracket for the long pivot bolt on the pump itself be the best fit for this?
This is not a drop-in product. Bracket took some modification to fit a P type pump as intended- 14mm ground off the pump reservoir "flange" area and 6mm off the rest of the area where the reservoir body sits. Picture before cleaning up the grinds and painting.... next step will be mounting and either stacking washers or cutting spacers to locate the pulley properly.
Up
Mark I will take bracket and adjuster. Can u send me a total shipping to 53142. I will send a check.
$130 to your door. Thanks for the business.😊
Still have any of those? Left you a VM a few minutes ago.
I do. And I still have a $100 minimum order. And I sell a LOT of the same replacement parts that other vendors do to help make that minimum.😉
